Network a camera through RBWAPG-60AD-A
I purchased two RBWAPG-60AD-A and am hoping to do a wireless wire configuration to connect a remote IP camera on a light pole to the network. Is it possible to do this without a switch on the pole?
  • POE injector 01 to camera
  • POE injector 02 to AP
  • Connect the two POE injectors together
If the question is whether you can connect the LAN side of Injector 1 to the LAN side of the Injector 2, yes.
That is the question. Thank you!
