Hello
Is there a script I can run that will tell me if the network cable is unplugged on ether1?
I am making a 12v UPS and using a loopback cable to tell me if teh powers one or off (cable looped or not)
Thanks ![]()
Hello
Thanks ![]()
I got this so far
/interface ethernet monitor [/interface ethernet find name "ether5"] once do {
:if ($status="no-link") do {
/tool e-mail send to="equis@mymailadd.com.au" subject=("Power Failure At") body=("Power Failure at at")
is the ok?
I get error sending in log, need to find where to put smtp server
Would someone know where to put smtp server?
Thanks ![]()
EDIT: /tool e-mail set
OK, Last problem
Can I get it to email ony when its changed?
It currently emails me every min ![]()
Set global variable which is set to true if email already sent. And set to false if link is ok ![]()
Thanks ![]()
