Network card drivers?
How do you upload the drivers for a network card when using RouterOS?
it’s not possible.
So when using RouterOS on a PC, its impossible to change the network cards drivers?
Sorry for the repetition, I just need clarification
Note, that RouterOS is standalone OS, it means you are not able to run second OS simultaneously (without VM).
It is not possible to load drivers into the RouterOS.
RouterOS already has all the drivers inside it. you don’t have to install anything. just plug in and start up.
