Hello.
I have an x86 machine and a bunch of identical 100mbps pci network cards (Davicom 18-1d-p200-cb, DM9102AF chip). They are tested and work flawlessly under linux (gentoo, ubuntu, etc), but are not added as ethernet interfaces if I boot into ROS. It finds and uses a builtin gigabit ethernet card and a Dlink one, but not these. I’d like to put them into use, since they satisfy my needs nicely.
I’ve googled a lot, and I’ve found that the card is supported - it’s listed under a supported hardware section: https://wiki.mikrotik.com/wiki/Manual:D … com_DM9102
It is shown in system->resources->pci, and the driver in system->drivers is loaded, but it looks as if it’s a wrong one - simply the next one from the supported hardware list - FX/TX DEC 21140AF.
I’ve tried several versions of ROS (6.38.x, 6.39.3, 6.40.4), but it doesn’t work.
I can’t attach a supout.rif file, since the forum gives an error about an unsupported file extension, so I’ve uploaded it here: http://mooov.ru/stuff/supout.rif
It would be nice if you tell me what to do with this, or fix this bug in later ROS versions.
