network drive
is is possible to mount network drive to routerboard? using nfs or iscsi? I would like to map some storage from my NAS.
unfortunately, no
The logging system has options for iSCSI… so i would “belive” the code is there for the init.
But it is NOT exposed to the system at this time (cant mount an iSCSI target and have it show up in the “STORES”)..
So i think I would say, “Not at this time”..
Can anyone confirm, is this still the case?
I am using an RB750 and want to know if I can use my external server for added storage for the User Manager.
D
I’m playing with the new v7 ROSE-storage and nfs4 mount. It should be possible on paper, yet I cant make it work so far .
I believe it requires nfs4.1 in order to mount properly share on ROS.
currently I find rose-storage a bit buggy, i.e doest not mount iscsii from qnap/Synology NAS at all, causing hangout.
