network joinning
i have tow networks
network1-mikrotik ospf network(address added)—ethernet cable----ubiqity bridged-network2
on mikrotik i hve dhcp clint to gain address from bridgenetwork2 works fine
but i can ping the hole network from the mikrotik
and not from behind the mikrotik but if i look at ospf my hole network should see it
please help me slove this problem
Does devices behind mikrotik router know how to reach bridgenetwork2?
well it should
ospf tell me that the rouse to 192.168.2.0/24 goes to that interface
net1-----mik(eth)-cable–ubiquity(briged)net—net2
net1 is all osf routing!
and mik(eth)has static dhcpclient set up
eth gets its address
ospf routes it
the route gets placed on the table
and can ping the address that was given to the eth port
but nothing behind it
