Network Map Links not visible after Discovery
I am a new user for The Dude - so please be patient :slight_smile:.
Everything is setup using the CHR and Discovery runs fine. However, no Links are showing up on the Network Map. There are no physical Switches in the environment I am using for Network Map. Is that needed for Links to appear? The entire environment is a set of VMs running on Hyper-V and all I am trying to do is establish a Network Map showing all the Links between the VMs. I can manually add the links but I was under the impression that The Dude will create the links for me automatically.
I do not have SNMP enabled on any of the VMs and I have the “Add Links” check box enabled in the Discovery dialog settings. Thanks.
