Network printer issue
I’m a beginner to Mikrotik. I have a network printer with a local IP address. I want to set the printer to make it applicable to receive requests from other PCs outside my network. The problem is that the printer IP is local. This means that I need to find out how to apply port forwarding settings in Mikrotik so I can use an external IP as a network printer address.
How can I do that ? Is there a better way to do it in Mikrotik ?
Thanks.
Use port forwarding - described here: http://wiki.mikrotik.com/wiki/Forwarding_a_port_to_an_internal_IP
