Dear all please I have a network where i run hotspot as the mode of authentication. Since i installed the hotspot, all the network printers doesnt print fast. Most times we send a document to the printer, it will not print immediately or may not even print at all until the printer and system is rebooted. Some times it will not print, then after some hours the document will print out when another document is sent for print out. Does any one have an idea of how i can solve this issue?
You will have problems communicating with other devices on the hotspot network unless you disable the hotspot nat.
/ip hotspot
set 0 address-pool=none
