Network share via WLAN unreachable
We have a issue with our wlan all MikroTik CAPsMAN connecting to our network shares on our fileserver. The network shares is timing out when trying to connect to the server. If you connect the LAN it works perfectly fine. If you restart the File Server the network shares works again on the wlan for awhile and then starts timing out again. The server is reachable via ping on its hostname.
So basically smb is not working on wlan. I did also check if the firewall profile is public or domain, it is on domain.
Any assistance would be appreciated?
Local forwarding and client to client forwarding on?
