Hi
Does any1 know any network simulator program that works with mikrotik router. There are many available with cisco routers.
thnx
Hi
thnx
thats a good idea dude was also tryna to look forward to the same idea but am afraid had searched the net to no avail they have to develop 1 like cisco that would be great try this one
http://www.fileheap.com/transfer.php?id=12651&url=3735363535333333336137653266373536323f3e36303f323135363632363761363a343d3365363733313635336537303e3436323e373032366233653761363431613230363232623266363736383f3737313e333032363537643636373434653766373032313566363736363e3037663a65316437363333
There’s no such thing.
You can, however, use RouterOS in a virtual machine. The demo license still runs for 24 hours for free.
I always use VMWARE workstation, and have successfully tested almost every scenario in the LAB, before deploying it on the production environment
Yeah, VMware workstation is the solution. You can use the teams function and set up large complex networks down to controlling the speed on individual network segments. A RouterOS VM is small and doesn’t need much ram so you can easily do a large number of machines. You can toss a desktop VM in the mix too and test what a user would see.
