Hi everyone,
I’m new to this forum and currently facing an issue with configuring WireGuard to connect two MikroTik routers (hEX S, wAP ac LTE kit) over a DigitalOcean-hosted Ubuntu v24 server. Both routers are intended to operate within the same subnet (192.168.69.0/24). Despite spending several days setting up and poring over manuals, I’m unable to establish connectivity between the two routers, which are currently on my workbench (they will be separated by a significant distance in the future).
Here’s a more detailed breakdown of my issue:
When I attempt to ping from either MikroTik router, I get the following responses indicating that the host is unreachable:
[admin@MikroTik] > ping 192.168.69.161
SEQ HOST SIZE TTL TIME STATUS
0 10.0.0.1 84 64 86ms687us host unreachable
1 10.0.0.1 84 64 86ms31us host unreachable
From the Ubuntu server, pinging any of the MikroTik IPs results in:
root@ubuntu-vm:~# ping 192.168.69.161
PING 192.168.69.161 (192.168.69.161) 56(84) bytes of data.
From 10.0.0.1 icmp_seq=1 Destination Host Unreachable
--- 192.168.69.161 ping statistics ---
4 packets transmitted, 0 received, +4 errors, 100% packet loss, time 3094ms
The WireGuard interface seems to be up with the following configuration:
root@ubuntu-vm:~# wg
interface: wg0
public key: <public key server>
private key: (hidden)
listening port: 51830
peer: <public key1>
endpoint: 67.123.228.14:51830
allowed ips: 10.0.0.2/32
latest handshake: 1 minute, 35 seconds ago
transfer: 70.59 KiB received, 23.84 KiB sent
peer: <public key2>
endpoint: 67.123.228.14:16432
allowed ips: 10.0.0.3/32
latest handshake: 1 minute, 50 seconds ago
transfer: 341.47 KiB received, 388.53 KiB sent
peer: <public key3>
allowed ips: 10.0.0.4/32, 192.168.69.0/24
Each peer’s allowed IPs are properly set, and the interface and peers appear to be configured correctly. However, connectivity between the routers remains unsuccessful.
Wireguard VPN.pdf (180 KB)
