new 4WAN PCC not working -can you help?
Hello ,
I’m trying to run 4 wan using this configuration
https://www.youtube.com/watch?v=Rje_EsyGjwo
this is the configuration :
/ip firewall address-list
add address=10.0.0.0/24 list=custumer
add address=10.44.24.58 list=lte1
add address=10.86.176.178 list=lte2
add address=10.136.211.140 list=lte3
add address=46.210.166.172 list=lte4
/ip firewall mangle
add chain=prerouting comment=*88888888888888888888* dst-address-list=lte1 \
    src-address-list=custumer
add chain=prerouting dst-address-list=custumer src-address-list=custumer
add chain=prerouting dst-address-list=lte1 in-interface=bridge1
add action=mark-connection chain=prerouting comment=*111111* connection-mark=\
    no-mark in-interface=WAN1 new-connection-mark=WAN1_conn
add action=mark-connection chain=prerouting connection-mark=no-mark \
    in-interface=WAN2 new-connection-mark=WAN2_conn
    in-interface=WAN3 new-connection-mark=WAN3_conn
    in-interface=WAN4 new-connection-mark=WAN4_conn
add action=jump chain=prerouting comment=jump connection-mark=no-mark \
    in-interface=bridge1 jump-target=policy_routing
add action=mark-routing chain=prerouting comment=***** connection-mark=\
    WAN1_conn new-routing-mark=WAN1_traffic src-address-list=custumer
add action=mark-routing chain=prerouting connection-mark=WAN2_conn \
    new-routing-mark=WAN2_traffic src-address-list=custumer
add action=mark-routing chain=prerouting connection-mark=WAN3_conn \
    new-routing-mark=WAN3_traffic src-address-list=custumer
add action=mark-routing chain=prerouting connection-mark=WAN4_conn \
    new-routing-mark=WAN4_traffic src-address-list=custumer
add action=mark-routing chain=output comment=routing connection-mark=\
add action=mark-routing chain=output connection-mark=WAN2_conn \
add action=mark-routing chain=output connection-mark=WAN3_conn \
add action=mark-routing chain=output connection-mark=WAN4_conn \
add action=mark-connection chain=policy_routing comment=PCC dst-address-type=\
    !local new-connection-mark=WAN1_conn per-connection-classifier=\
    both-addresses:4/0
add action=mark-connection chain=policy_routing dst-address-type=!local \
    new-connection-mark=WAN2_conn per-connection-classifier=\
    both-addresses:4/1
    new-connection-mark=WAN3_conn per-connection-classifier=\
    both-addresses:4/2
    new-connection-mark=WAN4_conn per-connection-classifier=\
    both-addresses:4/3
add action=masquerade chain=srcnat out-interface=WAN1
add action=masquerade chain=srcnat out-interface=WAN2
add action=masquerade chain=srcnat out-interface=WAN3
add action=masquerade chain=srcnat out-interface=WAN4
add check-gateway=ping comment=lololl distance=1 gateway=WAN1 routing-mark=\
    WAN1_traffic
add check-gateway=ping distance=1 gateway=WAN2 routing-mark=WAN2_traffic
add check-gateway=ping distance=1 gateway=WAN3 routing-mark=WAN3_traffic
add check-gateway=ping distance=1 gateway=WAN4 routing-mark=WAN4_traffic
add check-gateway=ping distance=2 gateway=WAN2
add check-gateway=ping distance=3 gateway=WAN3
add check-gateway=ping distance=4 gateway=WAN4
add check-gateway=ping distance=5 gateway=WAN1
but only WAN1 is working -
why is it?
