New 951g - very slow remote connections...
I’ve picked up a new 951g-2HnD router with OS 5.26 and I’ve exhausted my (admittedly limited) ability to get it working properly.
I have 2-line MLPPP setup using ports 1 and 2 as inputs for the PPPOE-out interface. This piece works and both lines connect to my ISP almost instantaneously.
I’m using ports 3, 4 and 5 for a home network devices. Plugging a laptop into ether3 I can access the internet but conections are very slow. I initially thought there was a dns server conflict but even with an IP address remote servers take a long time to conect. As an example, web pages with lots of adds may take 5 minutes to load with some of the adds timing out. www.speedtest.net takes maybe 30 seconds to load but it only has a few adds on it. Once the page is loaded i can re-run the speedtest instantaneously, and as often as I want and it shows my upload and downloads running at full speed since the site doesn’t force a reload of adds. From my ISP’s speedtest page I get results like this:
Last Result:
Download Speed: 17488 kbps (2186 KB/sec transfer rate)
Upload Speed: 1653 kbps (206.6 KB/sec transfer rate)
Sunday, March 16, 2014 3:33:44 PM
This is with 2 DSL lines @ 10 Mbps download, 1.08Mbps upload each so speed is where I’d expect it to be considering MLPPP overhead. I should note that the longer i spend online the more likely it is that I’ll get a remote timeout message. Any ideas? I’ve spent a lot of time Googling so far without success and have reconfigured the router so many times now I’m just going around in circles. I can upload whatever logs are necessary to troubleshoot (may need instructions to do so).
Rick
Did some more digging and I wonder if I’ve found something. I’ve included a capture of my export but in it I see the following:
/ip dhcp-client
add add-default-route=yes default-route-distance=1 disabled=no interface=
DSL1-705-722.**** use-peer-dns=yes use-peer-ntp=yes
I know I’ve changed this from DSL1-705-722.**** (my ether1 interface) to the pppoe-out1 interface several times now but for some reason it keeps reverting to ether1 (my MLPPP connection bonds ether1 and ether2). Is it supposed to do this? Is this the cause my my issue? It seems that after maybe 5 minutes my connection is totally unresponsive. I’ve also included a copy of my home network diagram so you can see what I’m trying to do. The 951g is at address 192.168.0.1 with a D-Link DIR-655 at 192.168.0.2 operating as an AP / switch. Would appreciate any assistance anyone can give.
Rick
Home Network.pdf (746 KB)
Export:
[admin@MikroTik] > export
jan/03/1970 06:26:34 by RouterOS 5.26
software id = 7M64-WA44
set 0 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited
disabled=no full-duplex=yes l2mtu=1598 mac-address=D4:CA:6D:D0:88:04
master-port=none mtu=1500 name=DSL1-705-722.**** speed=100Mbps
set 1 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited
disabled=no full-duplex=yes l2mtu=1598 mac-address=D4:CA:6D:D0:88:05
master-port=none mtu=1500 name=DSL2-705-725-**** speed=100Mbps
set 2 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited
disabled=no full-duplex=yes l2mtu=1598 mac-address=D4:CA:6D:D0:88:06
master-port=none mtu=1500 name=ether3-master speed=1Gbps
set 3 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited
disabled=no full-duplex=yes l2mtu=1598 mac-address=D4:CA:6D:D0:88:07
master-port=ether3-master mtu=1500 name=ether4 speed=100Mbps
set 4 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited
disabled=no full-duplex=yes l2mtu=1598 mac-address=D4:CA:6D:D0:88:08
master-port=ether3-master mtu=1500 name=ether5 speed=100Mbps
/interface ethernet switch
set 0 mirror-source=none mirror-target=none name=switch1
set [ find default=yes ] authentication-types=wpa2-psk eap-methods=“”
group-ciphers=aes-ccm group-key-update=5m interim-update=0s
management-protection=disabled management-protection-key=“” mode=
dynamic-keys name=default radius-eap-accounting=no radius-mac-accounting=
no radius-mac-authentication=no radius-mac-caching=disabled
radius-mac-format=XX:XX:XX:XX:XX:XX radius-mac-mode=as-username
static-algo-0=none static-algo-1=none static-algo-2=none static-algo-3=
none static-key-0=“” static-key-1=“” static-key-2=“” static-key-3=“”
static-sta-private-algo=none static-sta-private-key=“”
static-transmit-key=key-0 supplicant-identity=MikroTik tls-certificate=
none tls-mode=no-certificates unicast-ciphers=aes-ccm wpa-pre-shared-key=
" wpa2-pre-shared-key=
/interface wireless
set 0 adaptive-noise-immunity=none allow-sharedkey=no antenna-gain=0 area=“”
arp=enabled band=2ghz-b/g/n basic-rates-a/g=6Mbps basic-rates-b=1Mbps
bridge-mode=enabled channel-width=20/40mhz-ht-above compression=no
country=canada default-ap-tx-limit=0 default-authentication=yes
default-client-tx-limit=0 default-forwarding=yes dfs-mode=none
disable-running-check=no disabled=no disconnect-timeout=3s distance=
dynamic frame-lifetime=0 frequency=2412 frequency-mode=manual-txpower
frequency-offset=0 hide-ssid=no ht-ampdu-priorities=0 ht-amsdu-limit=8192
ht-amsdu-threshold=8192 ht-basic-mcs=
mcs-0,mcs-1,mcs-2,mcs-3,mcs-4,mcs-5,mcs-6,mcs-7 ht-guard-interval=any
ht-rxchains=0 ht-supported-mcs=“mcs-0,mcs-1,mcs-2,mcs-3,mcs-4,mcs-5,mcs-6,
mcs-7,mcs-8,mcs-9,mcs-10,mcs-11,mcs-12,mcs-13,mcs-14,mcs-15,mcs-16,mcs-17,
mcs-18,mcs-19,mcs-20,mcs-21,mcs-22,mcs-23” ht-txchains=0
hw-fragmentation-threshold=disabled hw-protection-mode=none
hw-protection-threshold=0 hw-retries=7 l2mtu=2290 mac-address=
D4:CA:6D:D0:88:09 max-station-count=2007 mode=ap-bridge mtu=1500
multicast-helper=default name=wlan1 noise-floor-threshold=default
nv2-cell-radius=30 nv2-noise-floor-offset=default nv2-preshared-key=“”
nv2-qos=default nv2-queue-count=2 nv2-security=disabled
on-fail-retry-time=100ms periodic-calibration=default
periodic-calibration-interval=60 preamble-mode=both
proprietary-extensions=post-2.9.25 radio-name=D4CA6DD08809
rate-selection=advanced rate-set=default scan-list=default
security-profile=default ssid=MikroTik station-bridge-clone-mac=
00:00:00:00:00:00 supported-rates-a/g=
6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps supported-rates-b=
1Mbps,2Mbps,5.5Mbps,11Mbps tdma-period-size=2 tx-power-mode=default
update-stats-interval=disabled wds-cost-range=50-150 wds-default-bridge=
none wds-default-cost=100 wds-ignore-ssid=no wds-mode=disabled
wireless-protocol=802.11 wmm-support=disabled
/interface wireless manual-tx-power-table
set wlan1 manual-tx-powers=“1Mbps:17,2Mbps:17,5.5Mbps:17,11Mbps:17,6Mbps:17,9M
bps:17,12Mbps:17,18Mbps:17,24Mbps:17,36Mbps:17,48Mbps:17,54Mbps:17,HT20-0:
17,HT20-1:17,HT20-2:17,HT20-3:17,HT20-4:17,HT20-5:17,HT20-6:17,HT20-7:17,H
T40-0:17,HT40-1:17,HT40-2:17,HT40-3:17,HT40-4:17,HT40-5:17,HT40-6:17,HT40-
7:17”
/interface wireless nstreme
set wlan1 disable-csma=no enable-nstreme=no enable-polling=yes framer-limit=
3200 framer-policy=none
/ip hotspot profile
set [ find default=yes ] dns-name=“” hotspot-address=0.0.0.0 html-directory=
hotspot http-cookie-lifetime=3d http-proxy=0.0.0.0:0 login-by=
cookie,http-chap name=default rate-limit=“” smtp-server=0.0.0.0
split-user-domain=no use-radius=no
/ip hotspot user profile
set [ find default=yes ] idle-timeout=none keepalive-timeout=2m name=default
shared-users=1 status-autorefresh=1m transparent-proxy=no
/ip ipsec proposal
set [ find default=yes ] auth-algorithms=sha1 disabled=no enc-algorithms=3des
lifetime=30m name=default pfs-group=modp1024
add name=dhcp ranges=192.168.0.100-192.168.0.254
add address-pool=dhcp authoritative=after-2sec-delay bootp-support=static
disabled=no interface=ether3-master lease-time=3d name=dhcp1
disabled=no interface=wlan1 lease-time=3d name=dhcp2
/ppp profile
set 0 change-tcp-mss=yes name=default only-one=default use-compression=
default use-encryption=default use-mpls=default use-vj-compression=
default
set 1 change-tcp-mss=yes name=default-encryption only-one=default
use-compression=default use-encryption=yes use-mpls=default
use-vj-compression=default
/interface pppoe-client
add ac-name=“” add-default-route=yes allow=pap,chap,mschap1,mschap2
dial-on-demand=no disabled=no interface=
DSL1-705-722.,DSL2-705-725- max-mru=1480 max-mtu=1480 mrru=
disabled name=pppoe-out1 password=******** profile=default service-name=
Acanac use-peer-dns=yes user=********@realm2.acanac.net
/queue type
set 0 kind=pfifo name=default pfifo-limit=50
set 1 kind=pfifo name=ethernet-default pfifo-limit=50
set 2 kind=sfq name=wireless-default sfq-allot=1514 sfq-perturb=5
set 3 kind=red name=synchronous-default red-avg-packet=1000 red-burst=20
red-limit=60 red-max-threshold=50 red-min-threshold=10
set 4 kind=sfq name=hotspot-default sfq-allot=1514 sfq-perturb=5
set 5 kind=none name=only-hardware-queue
set 6 kind=mq-pfifo mq-pfifo-limit=50 name=multi-queue-ethernet-default
set 7 kind=pfifo name=default-small pfifo-limit=10
/routing bgp instance
set default as=65530 client-to-client-reflection=yes disabled=no
ignore-as-path-len=no name=default out-filter=“” redistribute-connected=
no redistribute-ospf=no redistribute-other-bgp=no redistribute-rip=no
redistribute-static=no router-id=0.0.0.0 routing-table=“”
/routing ospf instance
set [ find default=yes ] disabled=no distribute-default=never in-filter=
ospf-in metric-bgp=auto metric-connected=20 metric-default=1
metric-other-ospf=auto metric-rip=20 metric-static=20 name=default
out-filter=ospf-out redistribute-bgp=no redistribute-connected=no
redistribute-other-ospf=no redistribute-rip=no redistribute-static=no
router-id=0.0.0.0
/routing ospf area
set [ find default=yes ] area-id=0.0.0.0 disabled=no instance=default name=
backbone type=default
/snmp community
set [ find default=yes ] addresses=0.0.0.0/0 authentication-password=“”
authentication-protocol=MD5 encryption-password=“” encryption-protocol=
DES name=public read-access=yes security=none write-access=no
/system logging action
set 0 memory-lines=100 memory-stop-on-full=no name=memory target=memory
set 1 disk-file-count=2 disk-file-name=log disk-lines-per-file=100
disk-stop-on-full=no name=disk target=disk
set 2 name=echo remember=yes target=echo
set 3 bsd-syslog=no name=remote remote-port=514 src-address=0.0.0.0
syslog-facility=daemon syslog-severity=auto target=remote
/user group
set read name=read policy=“local,telnet,ssh,reboot,read,test,winbox,password,w
eb,sniff,sensitive,api,!ftp,!write,!policy” skin=default
set write name=write policy=“local,telnet,ssh,reboot,read,write,test,winbox,pa
ssword,web,sniff,sensitive,api,!ftp,!policy” skin=default
set full name=full policy=“local,telnet,ssh,ftp,reboot,read,write,policy,test,
winbox,password,web,sniff,sensitive,api” skin=default
/interface bridge settings
set use-ip-firewall=no use-ip-firewall-for-pppoe=no use-ip-firewall-for-vlan=
no
set 0 vlan-header=leave-as-is vlan-mode=disabled
set 1 vlan-header=leave-as-is vlan-mode=disabled
set 2 vlan-header=leave-as-is vlan-mode=disabled
set 3 vlan-header=leave-as-is vlan-mode=disabled
set 4 vlan-header=leave-as-is vlan-mode=disabled
set 5 vlan-header=leave-as-is vlan-mode=disabled
/interface l2tp-server server
set authentication=pap,chap,mschap1,mschap2 default-profile=
default-encryption enabled=no keepalive-timeout=30 max-mru=1460 max-mtu=
1460 mrru=disabled
/interface ovpn-server server
set auth=sha1,md5 certificate=none cipher=blowfish128,aes128 default-profile=
default enabled=no keepalive-timeout=60 mac-address=FE:42:1E:F3:19:99
max-mtu=1500 mode=ip netmask=24 port=1194 require-client-certificate=no
/interface pptp-server server
set authentication=mschap1,mschap2 default-profile=default-encryption
enabled=no keepalive-timeout=30 max-mru=1460 max-mtu=1460 mrru=disabled
/interface sstp-server server
set authentication=pap,chap,mschap1,mschap2 certificate=none default-profile=
default enabled=no keepalive-timeout=60 max-mru=1500 max-mtu=1500 mrru=
disabled port=443 verify-client-certificate=no
/interface wireless align
set active-mode=yes audio-max=-20 audio-min=-100 audio-monitor=
00:00:00:00:00:00 filter-mac=00:00:00:00:00:00 frame-size=300
frames-per-second=25 receive-all=no ssid-all=no
/interface wireless sniffer
set channel-time=200ms file-limit=10 file-name=“” memory-limit=10
multiple-channels=no only-headers=no receive-errors=no streaming-enabled=
no streaming-max-rate=0 streaming-server=0.0.0.0
/interface wireless snooper
set channel-time=200ms multiple-channels=yes receive-errors=no
/ip accounting
set account-local-traffic=no enabled=no threshold=256
/ip accounting web-access
set accessible-via-web=no address=0.0.0.0/0
add address=192.168.0.1/24 disabled=no interface=wlan1 network=192.168.0.0
add address=192.168.0.1/24 disabled=no interface=ether3-master network=
192.168.0.0
/ip dhcp-client
/ip dhcp-server config
set store-leases-disk=5m
add address=192.168.0.0/24 dhcp-option=“” dns-server=“” gateway=192.168.0.1
netmask=24 ntp-server=“” wins-server=“”
set allow-remote-requests=yes cache-max-ttl=1w cache-size=2048KiB
max-udp-packet-size=4096 servers=67.55.0.11,66.49.220.95
/ip dns static
add address=192.168.0.1 disabled=no name=Router ttl=1d
set enabled=yes generic-timeout=10m icmp-timeout=10s tcp-close-timeout=10s
tcp-close-wait-timeout=10s tcp-established-timeout=1d
tcp-fin-wait-timeout=10s tcp-last-ack-timeout=10s
tcp-syn-received-timeout=5s tcp-syn-sent-timeout=5s tcp-syncookie=no
tcp-time-wait-timeout=10s udp-stream-timeout=3m udp-timeout=10s
add action=drop chain=input comment=“Drop invalid Connections”
connection-state=invalid disabled=no
add action=accept chain=input comment=“Allow Established Connections”
connection-state=established disabled=no
add action=accept chain=input comment=“Allow ICMP” disabled=no protocol=icmp
add action=accept chain=input disabled=no in-interface=!pppoe-out1
src-address=192.168.0.0/24
add action=drop chain=input comment=“Drop Everything Else” disabled=no
add action=masquerade chain=srcnat disabled=no out-interface=
DSL1-705-722.**** to-addresses=0.0.0.0
add action=masquerade chain=srcnat disabled=no out-interface=pppoe-out1
/ip firewall service-port
set ftp disabled=no ports=21
set tftp disabled=no ports=69
set irc disabled=no ports=6667
set h323 disabled=no
set sip disabled=no ports=5060,5061 sip-direct-media=yes
set pptp disabled=no
/ip hotspot service-port
/ip neighbor discovery
set DSL1-705-722.**** disabled=no
set DSL2-705-725-**** disabled=no
set ether3-master disabled=no
set ether4 disabled=no
set ether5 disabled=no
set wlan1 disabled=yes
set pppoe-out1 disabled=yes
/ip proxy
set always-from-cache=no cache-administrator=webmaster cache-hit-dscp=4
cache-on-disk=no enabled=no max-cache-size=unlimited
max-client-connections=600 max-fresh-time=3d max-server-connections=600
parent-proxy=0.0.0.0 parent-proxy-port=0 port=8080 serialize-connections=
no src-address=0.0.0.0
/ip service
set telnet address=“” disabled=no port=23
set ftp address=“” disabled=no port=21
set www address=“” disabled=no port=80
set ssh address=“” disabled=no port=22
set www-ssl address=“” certificate=none disabled=yes port=443
set api address=“” disabled=yes port=8728
set winbox address=“” disabled=no port=8291
/ip smb
set allow-guests=yes comment=MikrotikSMB domain=MSHOME enabled=no interfaces=
all
/ip smb shares
set [ find default=yes ] comment=“default share” directory=/pub disabled=no
max-sessions=10 name=pub
/ip smb users
set [ find default=yes ] disabled=no name=guest password=“” read-only=yes
/ip socks
set connection-idle-timeout=2m enabled=no max-connections=200 port=1080
/ip traffic-flow
set active-flow-timeout=30m cache-entries=4k enabled=no
inactive-flow-timeout=15s interfaces=all
/ip upnp
set allow-disable-external-interface=yes enabled=no show-dummy-rule=yes
/mpls
set dynamic-label-range=16-1048575 propagate-ttl=yes
/mpls interface
set [ find default=yes ] disabled=no interface=all mpls-mtu=1508
/mpls ldp
set distribute-for-default-route=no enabled=no hop-limit=255 loop-detect=no
lsr-id=0.0.0.0 path-vector-limit=255 transport-address=0.0.0.0
use-explicit-null=no
/port firmware
set directory=firmware ignore-directip-modem=no
/ppp aaa
set accounting=yes interim-update=0s use-radius=no
/queue interface
set DSL1-705-722.**** queue=only-hardware-queue
set DSL2-705-725-**** queue=only-hardware-queue
set ether3-master queue=only-hardware-queue
set ether4 queue=only-hardware-queue
set ether5 queue=only-hardware-queue
set wlan1 queue=wireless-default
/radius incoming
set accept=no port=3799
/routing bfd interface
set [ find default=yes ] disabled=no interface=all interval=0.2s min-rx=0.2s
multiplier=5
/routing mme
set bidirectional-timeout=2 gateway-class=none gateway-keepalive=1m
gateway-selection=no-gateway origination-interval=5s preferred-gateway=
0.0.0.0 timeout=1m ttl=50
/routing rip
set distribute-default=never garbage-timer=2m metric-bgp=1 metric-connected=1
metric-default=1 metric-ospf=1 metric-static=1 redistribute-bgp=no
redistribute-connected=no redistribute-ospf=no redistribute-static=no
routing-table=main timeout-timer=3m update-timer=30s
/snmp
set contact=“” enabled=no engine-id=“” location=“” trap-generators=“”
trap-target=“” trap-version=1
/system clock
set time-zone-name=manual
/system clock manual
set dst-delta=+00:00 dst-end=“jan/01/1970 00:00:00” dst-start=
“jan/01/1970 00:00:00” time-zone=+00:00
/system identity
set name=MikroTik
/system leds
set 0 disabled=no interface=wlan1 leds=wlan-led type=wireless-status
/system logging
set 0 action=memory disabled=no prefix=“” topics=info
set 1 action=memory disabled=no prefix=“” topics=error
set 2 action=memory disabled=no prefix=“” topics=warning
set 3 action=echo disabled=no prefix=“” topics=critical
/system note
set note=“” show-at-login=yes
/system ntp client
set enabled=no mode=broadcast primary-ntp=0.0.0.0 secondary-ntp=0.0.0.0
/system resource irq
set 0 cpu=auto
set 1 cpu=auto
set 2 cpu=auto
set 3 cpu=auto
set 4 cpu=auto
/system routerboard settings
set boot-device=nand-if-fail-then-ethernet boot-protocol=bootp cpu-frequency=
600MHz force-backup-booter=no silent-boot=no
/system upgrade mirror
set check-interval=1d enabled=no primary-server=0.0.0.0 secondary-server=
0.0.0.0 user=“”
/system watchdog
set auto-send-supout=no automatic-supout=yes no-ping-delay=5m watch-address=
none watchdog-timer=yes
/tool bandwidth-server
set allocate-udp-ports-from=2000 authenticate=yes enabled=yes max-sessions=
100
/tool e-mail
set address=0.0.0.0 from=<> password=“” port=25 starttls=no user=“”
/tool graphing
set page-refresh=300 store-every=5min
/tool mac-server
/tool mac-server mac-winbox
/tool mac-server ping
set enabled=yes
/tool sms
set allowed-number=“” channel=0 keep-max-sms=0 receive-enabled=no secret=“”
/tool sniffer
set file-limit=1000KiB file-name=“” filter-ip-address=“” filter-ip-protocol=
“” filter-mac-address=“” filter-mac-protocol=“” filter-port=“”
filter-stream=yes interface=all memory-limit=100KiB memory-scroll=yes
only-headers=no streaming-enabled=no streaming-server=0.0.0.0
/tool traffic-generator
set latency-distribution-scale=10 test-id=0
/user aaa
set accounting=yes default-group=read exclude-groups=“” interim-update=0s
use-radius=no
[admin@MikroTik] >
