new bios 2.16 is out
What’s new in 2.16:
*) fixed bug - boot from NAND on RB532A could fail;
*) fixed bug - etherboot on RB433/RB450 at 10Mbit did not work;
When I try to upgrade from the link above, my RB411AH indicates the file is corrupt. Can someone verify the link and the size of the file. It could be just me, of course.
did you use this file? http://routerboard.com/files/rb-2.16/ar7100-2.16.fwf
the file is 33256 bytes (~32Kb)
Eh, no… Hence undoubtably the reason for the failure…
I used:
http://routerboard.com/files/rb-2.16/adm5120-2.16.fwf
Thanks..
use the link below your routerboard model, doh :slight_smile:
http://routerboard.com/comparison.html
Thanks, I understand and will not make that mistake again.. :open_mouth: http://forum.mikrotik.com/posting.php?mode=reply&f=3&t=24721#
And as you say, D O H !!http://forum.mikrotik.com/posting.php?mode=reply&f=3&t=24721#
For RB532 is there?? http://www.routerboard.com/files/rb-2.16/rc32434-2.16.fwf
If yes, can you add this link to routerboard.com?
You have bad link there.
routerboard.com → products → archive → RB532
Yes, but there is bad link to 2.16 for RB532
link fixed
