New Buyer
I have a 1 Gig connection modem ( netgear CM1200 ). That comes out as 2 1Gig network cable.
I Need router that logins in to the modem for connection.
“wan aggregation” and a one 10 Gig port ( don’t care what type ) coming out of the router
( if possible at least 1 normal 1gig network cable) .
[ want to go from Modem to { a MikroTik router } Out to two conections
1 1Gig network cable into router ( asus ( for wireless ))
1 10Gig line ( open to any type)
What is the lowest price model that I can get to do this?
Only need it to do Wan Aggregation , login in to my ISP , and out put to a router and to one 10Gig connected PC.
Just thought I would ask first here. Before , taking a guess and returning them.
What kind of login does the ISP need? PPPoE or captive portal or?
Any kind of gigabit port device with a 10G port will do.
Like this one https://mikrotik.com/product/rb4011igs_rm
I would normally recommend the same based on specs for normal ethernet activity, however if you wish to access your router for configuration while not at home, or have need for other VPN setups then, this is not the right unit to make maximum advantage of your 1gig wan connection.
For 1gig across most router functions, including ipsec, and 10g SFP…
https://mikrotik.com/product/CCR1009-7G-1C-1SplusPC - will keep you satisfied over the long haul.
Just the normal login. no User/password. No PPPoE.
I like this option,
Thank you.
