Hi, i am just wondering in old capsman / older wireless drivers support max band AC - there were more options of band combinations - be able run more bands/Wifi norm at same time.
For example
Older CAP
2GHz b/g/n
2GHz g/n
5GHz a/n/ac
5GHz n/ac
But new wireless friver and interfaces support AX there is not so many combinations, actually non - you can run one band/norm at time.
Specifically, lets say wAPG-5HaxD2HaxD
New CAP (wAPG-5HaxD2HaxD)
2GHz ax
2GHz g
2GHz N
5GHz a
5GHz a/n
5GHz ac
5GHz ax
Am I missing something or is it like this? Is there option in CAPsMAN, not to set in provisioning/Channel/Configuration more than one band? I guess its the HW thing. Means to make AP accessable for wide range of devices, you can not run it at AX (still lot of devices not supporting) so you end up with 2GHz N and 5GHz ac or 5GHz a/n.
So what is the point of AX :]]]
Or when running AX it still support all below like AC/N/A - meaning device support only N or only AC can still connect when AP set as AX?
Thnx
