New CAPsMAN config, winbox/client problems
Hi everyone,
I’m new to Mikrotik and would like some advice. I have a RBwAP2nDr2 connected to ETH5 (PoE) of a RB951Ui-2HnD. Using
https://youtu.be/Q9h00PYEzQM I setup CAPsMAN. Everything looks to be working ok but I could not do the config as described from https://youtu.be/Q9h00PYEzQM?t=341 here, ie locking the CAPs to the CAPsMAN and enabling certificates.
I have a few questions regarding this setup:
  1. Is it ok to run CAPs with CAPsMAN without the certificates and the CAPs locking?
  2. Is there a way to check what Frequencies and TX power of other CAPs each CAP can see. My client devices are jumping from one CAP to the other and I think this is because the cell overlap is to large. I would like to adjust TX power but would first like to know the level of the other CAP. (Hope that makes sense)
  3. Is it possible to connect to a CAP with Winbox? I’m using Winbox 3.11 and can see the wAP but can’t connect to it for some reason.The wAP is installed in a hard to reach place so it would be nice not to have to get the ladder to configure it (say to lock it to the CAPsMAN and setting up certificates)
  4. Would someone be willing to go over my configuration and highlight any potential security risks and or rules that might be giving me the the issue described in 2,3?
Below is an image of the neighbors list I see when starting Winbox 3.11. I can’t connect to the wAP with or without using my admin password.
Thanks in advance; Here is my config listing:
# oct/03/2017 19:17:00 by RouterOS 6.40.3
# software id = 70DS-LL74
# model = 951Ui-2HnD
# serial number = 6433064F6A93
/caps-man channel
add band=2ghz-b/g/n control-channel-width=20mhz extension-channel=disabled \
    frequency=2412 name=channel1
    frequency=2462 name=channel11
add admin-mac=6C:3B:6B:4C:1B:DB auto-mac=no comment=defconf name=bridge
set [ find default-name=ether2 ] name=ether2-master
set [ find default-name=ether3 ] master-port=ether2-master
set [ find default-name=ether4 ] master-port=ether2-master
set [ find default-name=ether5 ] master-port=ether2-master
/interface pppoe-client
add add-default-route=yes disabled=no interface=ether1 name=pppoe-out1 \
    password=******** service-name=isp-10mbps use-peer-dns=\
    yes user=username@isp.co.za
/interface wireless
# managed by CAPsMAN
# channel: 2462/20/gn(20dBm), SSID: MySSID, CAPsMAN forwarding
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-Ce \
    country="south africa" distance=indoors mode=ap-bridge ssid=MySSID \
    wireless-protocol=802.11
/ip neighbor discovery
set ether1 discover=no
/caps-man datapath
add bridge=bridge name=datapath1
/caps-man security
add authentication-types=wpa2-psk encryption=aes-ccm name=security1 \
    passphrase=**********
/caps-man configuration
add country="south africa" datapath=datapath1 distance=indoors mode=ap name=\
    cfg1 security=security1 ssid=MySSID
/caps-man interface
add channel=channel1 configuration=cfg1 datapath=datapath1 disabled=no l2mtu=\
    1600 mac-address=6C:3B:6B:9B:F5:44 master-interface=none name=cap1 \
    radio-mac=6C:3B:6B:9B:F5:44 security=security1
add channel=channel11 configuration=cfg1 datapath=datapath1 disabled=no \
    l2mtu=1600 mac-address=6C:3B:6B:4C:1B:DF master-interface=none name=cap2 \
    radio-mac=6C:3B:6B:4C:1B:DF security=security1
add comment=defconf name=WAN
add comment=defconf name=LAN
set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk mode=\
    dynamic-keys supplicant-identity=MikroTik wpa-pre-shared-key=********** \
    wpa2-pre-shared-key=**********
add name=dhcp ranges=192.168.88.10-192.168.88.254
add address-pool=dhcp disabled=no interface=bridge name=defconf
/caps-man manager
set enabled=yes
/caps-man provisioning
add action=create-dynamic-enabled master-configuration=cfg1
add bridge=bridge comment=defconf interface=ether2-master
/interface wireless cap
set bridge=bridge discovery-interfaces=bridge enabled=yes interfaces=wlan1
add address=192.168.88.1/24 comment=defconf interface=ether2-master network=\
    192.168.88.0
/ip dhcp-client
add comment=defconf dhcp-options=hostname,clientid interface=ether1
set allow-remote-requests=yes
/ip dns static
add address=192.168.88.1 name=router.lan
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
    established,related,untracked
    connection-state=invalid
    "defconf:  drop all from WAN not DSTNATed" connection-nat-state=!dstnat \
add action=accept chain=input connection-state=established
add action=accept chain=input connection-state=related
add action=drop chain=input in-interface=pppoe-out1
    ipsec-policy=out,none out-interface=pppoe-out1
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www address=192.168.88.0/24
set ssh address=192.168.88.0/24
set api disabled=yes
set winbox address=192.168.88.0/24
set api-ssl disabled=yes
/system clock
set time-zone-name=Africa/Johannesburg
/system identity
set name="MikroTik Office"
/tool mac-server
add interface=bridge
/tool mac-server mac-winbox
Ok, I’ve now seen the logs show that CAPs reconnect or swap channels so it seems the certificate and locking is required. So now my only question is how do I connect to a remote CAP using winbox. Say when the wAP is in a very hard to reach location. is this even possible?
Hi All,
Just to clarify something confusing,
So how is Capsman configured router identifies other CAP enabled APs? using WiFi ? or do we have to connect APs to Capsmanager router using cables?
Thanks :slight_smile:
Like I said, I’m no expert but yes it manages WiFi over the wired network.
