New CAPsMAN with dual AP's
Hi.
I started a new capsman with two types of access points - hap ax2 and cap ac. I use VLAN.
On Hap ax2, for some reason, tagged ports are dynamically created. When I transfer them to untagged, then wifi connects and disconnects constantly and does not work. It also does not work if I put bridge in datapath in the controller, although it is there in the configuration example.
On the contrary, untagged ports are dynamically created in CAP AC and only work like that.
Please help and tell me where I made a mistake in the settings
Controller:
/interface bridge add igmp-snooping=yes name=bridge1 vlan-filtering=yes
/interface vlan add interface=bridge1 name=vlan_120_WiFi vlan-id=120
/interface vlan add interface=bridge1 loop-protect=on name=vlan_200_Auth vlan-id=200
/interface vlan add interface=bridge1 loop-protect=on name=vlan_210_System_WiFi vlan-id=210
/interface wifi channel add band=2ghz-ax disabled=no frequency=2412,2437,2462 name=ch-24GHz-AX width=20mhz
/interface wifi channel add band=5ghz-ax disabled=no frequency=5150-5350,5650-5850 name=ch-5GHz-AX skip-dfs-channels=all width=20mhz
/interface wifi channel add band=2ghz-n disabled=no frequency=2412,2437,2462 name=ch-24GHz-N width=20mhz
/interface wifi channel add band=5ghz-ac disabled=no frequency=5150-5350,5650-5850 name=ch-5GHz-AC skip-dfs-channels=all width=20mhz
/interface wifi channel add band=5ghz-ac disabled=no frequency=5180,5200,5220,5240 name=ch-5GHz-AC-best skip-dfs-channels=all width=20mhz
/interface wifi channel add band=5ghz-ax disabled=no frequency=5180,5200,5220,5240 name=ch-5GHz-AX-best skip-dfs-channels=all width=20mhz
/interface wifi datapath add disabled=no name=datapath-Staff-AC-N
/interface wifi datapath add client-isolation=yes disabled=no name=datapath-Guest-AC-N
/interface wifi datapath add bridge-horizon=10 client-isolation=yes disabled=no name=datapath-Guest-AX vlan-id=200
/interface wifi datapath add client-isolation=no disabled=no name=datapath-Staff-AX vlan-id=120
/interface wifi security add authentication-types=wpa2-psk disabled=no ft=yes ft-over-ds=yes group-key-update=40m name=sec-Staff passphrase=SuperPassword
/interface wifi security add disabled=no ft=yes ft-over-ds=yes name=sec-Guest
/interface wifi security add authentication-types=wpa2-psk disabled=no ft=yes ft-over-ds=yes group-key-update=40m name=sec-SB passphrase=SuperPassword2
/interface wifi configuration add channel=ch-5GHz-AX-best datapath=datapath-Staff-AX disabled=no hide-ssid=yes mode=ap name=cfg-5Ghz-Staff-AX qos-classifier=dscp-high-3-bits security=sec-Staff ssid=Staff
/interface wifi configuration add channel=ch-24GHz-AX datapath=datapath-Staff-AX disabled=no hide-ssid=yes mode=ap name=cfg-24Ghz-Staff-AX qos-classifier=dscp-high-3-bits security=sec-Staff ssid=Staff
/interface wifi configuration add channel=ch-5GHz-AC-best disabled=no hide-ssid=yes mode=ap name=cfg-5Ghz-Staff-AC qos-classifier=priority security=sec-Staff ssid=Staff
/interface wifi configuration add channel=ch-24GHz-N disabled=no hide-ssid=no mode=ap name=cfg-24Ghz-Guest-N security=sec-Guest ssid=Guest
/interface wifi configuration add channel=ch-5GHz-AC-best disabled=no hide-ssid=no mode=ap name=cfg-5Ghz-Guest-AC security=sec-Guest ssid=Guest
/interface wifi configuration add channel=ch-24GHz-N disabled=no hide-ssid=yes mode=ap name=cfg-24Ghz-Staff-N qos-classifier=priority security=sec-Staff ssid=Staff
/interface wifi configuration add channel=ch-5GHz-AX-best datapath=datapath-Guest-AX disabled=no hide-ssid=no mode=ap name=cfg-5Ghz-Guest-AX security=sec-Guest ssid=Guest
/interface wifi configuration add channel=ch-24GHz-AX datapath=datapath-Guest-AX disabled=no hide-ssid=no mode=ap name=cfg-24Ghz-Guest-AX security=sec-Guest ssid=Guest
/interface wifi configuration add channel=ch-24GHz-N disabled=no hide-ssid=no mode=ap name=cfg-24Ghz-SB-N qos-classifier=priority security=sec-SB ssid=SB
/interface wifi configuration add channel=ch-24GHz-AX datapath=datapath-Staff-AX disabled=no hide-ssid=no mode=ap name=cfg-24Ghz-SB-AX qos-classifier=dscp-high-3-bits security=sec-SB ssid=SB
/interface bridge vlan add bridge=bridge1 tagged=bridge1,ether13 vlan-ids=200
/interface bridge vlan add bridge=bridge1 tagged=bridge1,ether13 vlan-ids=120
/interface bridge vlan add bridge=bridge1 tagged=bridge1,ether13 vlan-ids=210
/interface wifi access-list add action=accept allow-signal-out-of-range=10s disabled=no signal-range=-83..120
/interface wifi access-list add action=reject allow-signal-out-of-range=10s disabled=no signal-range=-120..-84
/interface wifi capsman set enabled=yes interfaces=vlan_120_WiFi package-path=sata1-part1/dude/files require-peer-certificate=no upgrade-policy=none
/interface wifi provisioning add action=create-dynamic-enabled disabled=no master-configuration=cfg-5Ghz-Staff-AX name-format=5GhzAX_Staff_%I slave-configurations=cfg-24Ghz-Guest-AX slave-name-format=5GhzAX_Guest_%I supported-bands=5ghz-ax
/interface wifi provisioning add action=create-dynamic-enabled disabled=no master-configuration=cfg-24Ghz-Staff-AX name-format=24GhzAX_Staff_%I slave-configurations=cfg-24Ghz-Guest-AX,cfg-24Ghz-SB-AX slave-name-format=24GhzAX_Guest_%I supported-bands=2ghz-ax
/interface wifi provisioning add action=create-dynamic-enabled disabled=no master-configuration=cfg-24Ghz-Staff-N name-format=24GhzN_Staff_%I slave-configurations=cfg-24Ghz-Guest-N,cfg-24Ghz-SB-N slave-name-format=24GhzN_Guest_%I supported-bands=2ghz-n
/interface wifi provisioning add action=create-dynamic-enabled disabled=no master-configuration=cfg-5Ghz-Staff-AC name-format=5GhzAC_Staff_%I slave-configurations=cfg-5Ghz-Guest-AC slave-name-format=5GhzAC_Guest_%I supported-bands=5ghz-ac
/interface wifi provisioning add action=none disabled=yes
/ip dhcp-client add interface=vlan_120_WiFi
Hap-ax2:
/interface bridge add name=bridge1 vlan-filtering=yes
/interface vlan add interface=bridge1 name=vlan_200_Auth vlan-id=200
/interface wifi datapath add bridge=bridge1 bridge-horizon=10 client-isolation=yes disabled=no name=data-cap-ax-guest vlan-id=200
/interface wifi datapath add bridge=bridge1 client-isolation=no disabled=no name=data-cap-ax-staff vlan-id=120
/interface wifi datapath add bridge=bridge1 disabled=no name=datapath1
/interface wifi
# managed by CAPsMAN
# mode: AP, SSID: Staff, channel: 5240/ax
set [ find default-name=wifi1 ] configuration.manager=capsman .mode=ap datapath=data-cap-ax-staff disabled=no
/interface wifi
# mode: AP, SSID: Staff, channel: 2437/ax
set [ find default-name=wifi2 ] configuration.manager=capsman .mode=ap datapath=data-cap-ax-staff disabled=no
/interface wifi
# mode: AP, SSID: Guest
add configuration.mode=ap datapath=data-cap-ax-guest disabled=no master-interface=wifi1 name=wifi3
/interface wifi
add configuration.mode=ap datapath=data-cap-ax-guest disabled=no master-interface=wifi2 name=wifi4
/interface wifi
# mode: AP, SSID: SB
add configuration.mode=ap datapath=data-cap-ax-staff disabled=no master-interface=wifi2 name=wifi5
/interface bridge port add bridge=bridge1 interface=ether1
/interface bridge vlan add bridge=bridge1 comment=Wi-Fi tagged=bridge1,ether1 vlan-ids=120
/interface bridge vlan add bridge=bridge1 comment=Auth tagged=bridge1,ether1 vlan-ids=200
/interface wifi cap set caps-man-addresses=10.10.12.2 enabled=yes slaves-datapath=datapath1 slaves-static=yes
/system identity set name=hAP_AX
CAP AC (manual config) :
/interface vlan add interface=bridge1 name=vlan120_WiFi vlan-id=120
/interface vlan add interface=bridge1 name=vlan200_Auth vlan-id=200
/interface wifi datapath add bridge=bridge1 client-isolation=no disabled=no name=data-staff vlan-id=120
/interface wifi datapath add bridge=bridge1 bridge-horizon=10 client-isolation=yes disabled=no name=data-guest vlan-id=200
/interface wifi
# mode: AP, SSID: Staff, channel: 2412/n
set [ find default-name=wifi1 ] configuration.manager=capsman .mode=ap datapath=data-staff disabled=no
/interface wifi
# mode: AP, SSID: Staff, channel: 5180/ac
set [ find default-name=wifi2 ] configuration.manager=capsman .mode=ap datapath=data-staff disabled=no
/interface wifi
add configuration.mode=ap datapath=data-guest disabled=no master-interface=wifi2 name=wifi3
/interface wifi
add configuration.mode=ap datapath=data-guest disabled=no master-interface=wifi1 name=wifi4
/interface wifi
add configuration.mode=ap datapath=data-staff disabled=no master-interface=wifi1 name=wifi5
/interface bridge port add bridge=bridge1 interface=ether2
/interface bridge port add bridge=bridge1 interface=wifi1 pvid=120
/interface bridge port add bridge=bridge1 interface=wifi2 pvid=120
/interface bridge port add bridge=bridge1 horizon=10 interface=wifi3 pvid=200
/interface bridge port add bridge=bridge1 horizon=10 interface=wifi4 pvid=200
/interface bridge port add bridge=bridge1 interface=wifi5 pvid=120
/interface bridge vlan add bridge=bridge1 tagged=bridge1,ether1 untagged=wifi1,wifi2,wifi5 vlan-ids=120
/interface bridge vlan add bridge=bridge1 tagged=bridge1,ether1 untagged=wifi3,wifi4 vlan-ids=200
/ip dhcp-client add interface=vlan120_WiFi
That’s absolutely fine. You can think about the interface as about switch.
Why?
There are some limitations when using wifi-qcom-ac driver, mainly VLANs can not be dynamically asigned.
802.11ac chipsets do not support this type of VLAN tagging , but they can be configured as VLAN access ports in bridge settings.
= you shouldn’t use vlan-id in datapath on AC device.
Adding:
use create-enabled for provisioning and manually add those interfaces to bridge of AP with proper vlan handling.
See Help pages:
https://help.mikrotik.com/docs/spaces/ROS/pages/224559120/WiFi#WiFi-CAPusing"wifi-qcom-ac"package:
(PS and I know it says to use dynamic-enabled there but I don’t like interface-numbers to go up and up and up…
Also I highly doubt that with create-dynamic-enabled your vlan settings will survive each and every time. With create-enabled it should. I use it like that.)
I set vlan-ids on CAPs datapath, but not set it on controller.
I must to remove that both?
You shouldn’t even set datapath at all on CAPs side.
ahh the good ole days of a few lines of config, no capsmans and vlan filtering ala pcunite… Make MT great again LOL.
