Hi all
I am a proud new owner of a CCR1009-7G-1C-1S+PC. (yay!)
Powered up out of the box.
I am not getting a DHCP Server response from any port.
Tried all ports: combo1, ether1-7 - no luck.
My macbook’s thunderbolt ether adapter shows connected (green light) but no ip address is ever assigned.
Eventually, macbook self-assigns an ip address and unable to ping 192.168.88.1.
Indeed. Unlike most other MikroTik routers the CCR comes up with a blank configuration.
Very convenient, as you don’t need to delete all that “default configuration” crap.
But of course you have to know it…
You can also use a serial cable and enter some basic commands to make it part of your network.
(set a fixed address, or set a dhcp client)
That is in fact how I did it, I don’t like Winbox so much because I rarely have Windows systems
available and I mostly use the WebFig.
