new CCR1009 crashes when turned sideways
I just got a CCR-1009-8G-1S-1S+ in the mail Thursday and it seems to crash whenever I tilt it. It’s such a crazy problem that it took me a few times to figure out what was even causing it. If someone else has one on a bench can you see if it’s a shared flaw?
Is it a rackmount or a passive cooling unit? What is your room temperature? Do you see any temperatures raising in System->Health when you tilt the device? What is in log after the crash? Does it crash when tilted on other side?
got some time to look at it again-
this is on a bench in my office, the temperature is 68 degrees F in here, the tile proc gets to be around 54C.
it seems as though the turning sideways thing was a red herring- all you have to do is pick it up while it is running, or otherwise cause it to jostle slightly and it will crash. just once i was able to get an error message from the serial console during the crash, otherwise it just becomes unresponsive and the LCD freezes:
(1,1) got double fault interrupt: PC 0xffff_fff7_0000_16a8, ICS/PL 0x6
(1,1)        last interrupt ILL, next-to-last interrupt TILE_TIMER
(1,1)        original client PL fault PC 0xffff_fff7_004f_2888, ICS/PL 0x2
(1,1)        client PL system save regs: 0: 0xffff_fe00_7ee9_0004  1: 0xffff_fff5_0008_0a98  2: 0x1  3: 0x12_0164
(1,1) Full saved register dump:
(1,1) r0  0000_0000_0000_0002  r18 0000_0000_0000_0080  r36 ffff_fe00_0055_5e60
(1,1) r1  0000_0000_0000_0016  r19 ffff_fe00_7aef_f398  r37 ffff_fe00_0065_0100
(1,1) r2  0000_0008_2040_0005  r20 ffff_fe00_7aef_f390  r38 ffff_fffc_ffff_ffff
(1,1) r3  0000_0000_0000_0001  r21 0000_0000_0000_0001  r39 0000_0000_0000_0000
(1,1) r4  0000_0000_0000_0001  r22 0000_0000_0000_0000  r40 0000_0000_0000_0000
(1,1) r5  ffff_fe00_7aef_f574  r23 0000_0000_0000_0000  r41 0000_0000_0000_0000
(1,1) r6  0000_0000_0000_0000  r24 ffff_fe00_7ee8_fe28  r42 0000_0000_0000_0000
(1,1) r7  0000_0000_0000_0000  r25 ffff_fe00_7ee8_ff28  r43 0000_0000_0000_0000
(1,1) r8  0000_0000_0000_0000  r26 ffff_fe00_7ee8_ff78  r44 0000_0000_0000_0000
(1,1) r9  0000_0000_0000_0000  r27 ffff_fe00_7ee8_ff78  r45 0000_0000_0000_0000
(1,1) r10 0000_0000_0000_0000  r28 ffff_fe00_7ee8_ff98  r46 0000_0000_0000_0000
(1,1) r11 0000_0000_ffff_e505  r29 ffff_fe00_7ee8_ffa0  r47 0000_0000_0000_0000
(1,1) r12 0000_0000_0000_0001  r30 ffff_fe00_7ee8_0018  r48 0000_0000_0000_0000
(1,1) r13 0000_0000_0000_0001  r31 ffff_fe00_0054_00c0  r49 0000_0000_0000_0000
(1,1) r14 0000_0000_0000_0018  r32 ffff_fe00_0054_0100  r50 0000_0000_0000_0000
(1,1) r15 ffff_fff5_0008_0930  r33 ffff_fe00_7ee8_0010  r51 0000_0000_0000_0000
(1,1) r16 0000_0035_dcf0_4300  r34 0000_0000_0000_0000  r52 0000_0000_0000_0000
(1,1) r17 ffff_fe00_7d50_c018  r35 0000_0000_0000_0010  tp  0000_01f4_ffb4_0000
(1,1) lr  ffff_fff7_0002_9b10  sp  ffff_fe00_7ee8_ff20
(1,1) im  0000_003b_eae0_007e  ex0 ffff_fff7_0000_16a8  ex1 0000_0000_0000_0006
also, rackmount- 2 fans inside. they rarely come on.
Sounds like a hardware failure to me. Probably should not think much of this and return the device for RMA.
