Hello Mikrotik community!
I’ve recently designed a custom enclosure for the Mikrotik RouterBoard RBM33G, and I’d like to invite you to check it out and give it a try!
https://makerworld.com/en/models/1004072
Here’s what the enclosure offers:
- Two mounting options: Compatible with both 19" racks and DIN rails, making it versatile for various setups.
- Eight pre-drilled rSMA connector holes: Perfect for adding antennas or other accessories with minimal effort.
- Custom fit: Specifically designed for the RBM33G, ensuring a secure and snug placement.
- Professional design: Practical and clean aesthetics for any tech environment.
- The design can be easily modified to suit your needs – you can replace the logo or add your own text to personalize the enclosure for your setup or brand.
If you’re looking for a sleek and functional way to house your RBM33G, I’d love for you to give this design a go! I’m open to feedback and ideas for improvements, so feel free to share your thoughts here.
Looking forward to hearing your opinions and suggestions!
Cheers,
VanikCZ
