NEW feature :) "admin comment"
Hello MK people,
can you please add somethink like admin comment ? I think kind of comment, that can be used to store information for other administrators. Somewhere in the menu can be button “admin comment” and this will open box, in witch can be stored various notes… ?
:slight_smile:
thanks
You can use the sys-note feature. Create a text file named sys-note.txt and ftp it into the router or just drag and drop it into the files folder in winbox. The content of that file is displayed whenever someone log-in via terminal, telnet or ssh.
hmmm, thanks this is solution if we connect throught terminal, ssh or telnet, but not by winbox and its “unnecessarily complicated” to change content :slight_smile: especialy if we connect to MK throught terminal only once on the beginning of configuration :slight_smile:
/system note set note=
