Rules #0, #6 and #7 are around for quite some time (let’s say at least since 6.42 if not earlier … rule #0 is probably around ever since fast-track got introduced) … rule #4 is new to me as well …
Concur, #4 is a new default rule, the rest have, as has been stated, been around for a while.
What would the effect of rule 4 be mkx. An obvious question not answered …
An environmentally friendly post would have included the obvious negating the need for a question and the subsequent response.
You know what CAPsMAN is and that client devices need to connect to controller. But what if both are same device?
Previous firewall for input chain dropped packets from WAN, but current drops packets from “not LAN”. CAPsMAN connection in above case comes from loopback interface, but you can’t add it to LAN interface list, because MikroTik doesn’t show it to us as existing interface. So an extra rule is needed (if you use CAPsMAN to control same device, otherwise you can get rid of it).
Thank you sob so if the wifi controlle is on a wifi device ergo one needs to account for that.
Personally, I dont use Capsman for a two capac household, who needs all the overhead and complication but I can see where this could be an issue. I would setup capsman on my RB450Gx4 anyway…
In any case, not coming to a device anytime soon cause 6.45.2 needs some serious love and attention before it goes on any of my devices.
Seeing your comment in 6.45.2 thread, I’m not sure if your devices should be more affraid of buggy RouterOS or you. Or maybe I’m misinterpreting a totally innocent comment.
