New firmware 6.48.2 cannot surf internet
I have been using MikroTik for several years with success. I am and audio visual integrator and not a network admin. I have a standard setup on the rb3011 or rg750gs and I use only Winbox. Yesterday I did another install but had to give up because devices could not get online. Here is my process
Connect using Winbox
reset config
download updates and install
setup local ip range example 10.0.0.0/24
setup dhcp server example 10.0.0.100-10.0.0.254
tick a few boxes such as bridge all lan ports and allow remote requests
setup basic firewall
Normally have an excellent network and do basics such as make static IP addresses etc
Yesterday no devices would surf., I reset config to the default and devices could get online. Once I added local IP range and dhcp server no devices could surf, not sure exactly what change caused issue
Is it the new firmware or is there a known issue? Thanks for any tips
