5.755MHz - 5875MHz with 36dBm (EIRP). So this is a big big message for us who
are allowed to use 20db in 2,4 and 30db in 5,4 so far. The usage conditions are
the same than in 5,4 but only for commercial usage.
So please MT we want to use it in 2.9.47 with our RB500/R52Hs.
Dont forget to allow turbo mode
we need to know exact center frequecies for these new channels. Also we need to know how much should be decrease the tx-output for those frequencies since we support only TPC and not ATPC - currently it looks like we need to decrease it by 12.
By the power adjustment (Transmit power control, TPC) the average sum achievement is reduced and thus the influence on satellite receivers in the sum reduces. Fundamental requirements and Test procedures are in the European standard EN 302,502.
36-12db = 24 would make it senseless. The only solution is to fulfill the requirements
of EN302502. And only the equipment which does this is usable/sellable.
Stefan
the regulation
is only for WISP (commercially uses ) not for private use
since we donāt support ATPC the only way to add that is to decrease by 12db.
Another problem the 36 you can use for P-P and P-MP, but for MESH and AP-MP you should use 33. How to seperate it, because the software doesnāt know exacty for what purposes you are using this radio. Only option would be create two new countries - one for P-P/P-MP an other for MESH/AP-MP.
is ATPC a big problem? Can it be scripted? If I understand it right it is simply to reduce
power as long as connections are working. In a point to point situation this will be
simple (and will help as 36db gives good backbone links). An AP with more clients
has no real chance to reduce power as he never knows when the station with the
weakest signal is turned on.
This MESH-NonMesh is typical european/german. Never try to keep things easy.
2 Countries would be ok. If you make a checkbox in Wirlesss-Interfaceconfig the users
in other countries would have to twiddle around with european specialties.
Last time I checked, altering the TX power on the AP in ROS disconnects the CPEs - temporarily - which then have to re-associate. A script implementing ATPC would have that effect. That might render a ālegally usableā system but a very annoying one that customers might not like (dropped VOIP calls, etc).
Also, I donāt know if thatās true on a āstationā end - might have the same effect there too.
It might be that later wireless drivers donāt have this problem, but I donāt know.
Comments from MT people on this topcic would be welcome. Hopefully, theyāre already working on it ā¦
Yes. But in a point to point situation with stable signal this is acceptable.
This system would need some time at startup. But shouldnāt change power
very often after that.
Thatās fine for a short link.
But not if itās a long link, where weather effects adversely affects the link margin.
This is one of the whole reasons for ATPC, the transmitter only puts out high power in fade conditions - means power can be lower in clear conditions hence lessening interference for other links/users.
I sincerely hope the MT guys can (or have) at least solve the ādisconnect on TX power changeā so that scripting can be implemented, or better still, implement ātrueā ATPC.
Hint to developers: put some user-programmable parameters (min, max power, hysteresis, on:off:manual) in any ATPC system, so that users can fix site-specific problems. We did this on some of our other (non-radio) wireless products and it proves invaluable.
In one of the next RouterOS v3.0 we will add such two countries.
Country name: Germany 5.8 Fixed P-P
Official Range: 5755-5875
Bands: 5ghz,5ghz-10mhz,5ghz-5mhz
Band Range
Frequency range:5ghz 5770-5860
5ghz-10mhz 5765-5865
5ghz-5mhz 5765-5865
EIRP with out ATPC max 24dBm(256mW)
Country name: Germany 5.8 Fixed AP
Band Range
5ghz-5mhz 5765-5865
EIRP with out ATPC max 21dBm(128mW)
