new Groove A 52ac. WLAN not working.
I have a new Groove A 52ac that I’m trying to setup for the first time. PoE is setup correctly and I getting the expected LEDs blinking.
There is nothing in the available wireless interfaces. :open_mouth:
reset the settings to default, nothing has changed. I can’t find where to activate the wireless interface.
In the error log: error while running customized default configuration script: interrupted
What screen should I attach to make it more visual?
If anyone has encountered such a problem or knows how to solve it, please help!
I’m a beginner, but I’ve set up similar routers.
You tried reinstalling ROS with netinstall?
If not unmark “keep old configuration”.
Regards.
