New HAP ac2 as ATT Bridge (slow, sites not loading)
Well everything was actually solved except i haven’t figured out the QoS stuff yet, speeds are lower than expected since I was maxing the CPU out on the Edgerouter X with smart queue on and getting about 250 Mb and 5-10 ms bufferbloat.
Now I have 225 Mb and 100-500 ms bufferbloat.
I tried the walkthrough on QoS from PCUNITE but I assume I missed something cause it had no effect, I’m probably missing the part where I mark the traffic.
I tried option 1 first, speeds were low, bufferbloat was too high, and I don’t really have room for the Arris in my lan closet.
Option 2 would be my next choice.
In my case I’ve had the arris unplugged for several days now and no issues.
So you removed the Ariss and connected the HAP directly to the ONT with ether1 as I suggested?
In this case, reset the default configuration from the system menu or type “/system reset-configuration” from the terminal. This should enable fasttrack on the bridge. You can now connect a laptop to any remaining ether port and run a few speed tests while monitoring the CPU cores from System/Resources/CPU.
Run cmd in Windows and type:
ping 8.8.8.8 -t
What is the average speed, ping and cpu usage? What is the speed you are paying for?
This is an important baseline, because fasttrack bypasses most of the firewall stack and once it is disabled for QOS, cpu will increase by at least 30%, and thus affect overall bandwidth. Furthermore, any rules we set for QOS must limit your WAN connection even further to be effective.
Keep the cmd prompt running…
Once you have a baseline (best case scenario), we can experiment with queues. The first solution to bufferbloat is a simple queue. It’s a lazy hack, but it works with one major caveat: it’s resource intensive on a small HAP.
  1. You must add a new queue type for SFQ in the terminal:
/queue type
add kind=sfq name=sfq-default sfq-perturb=10
  1. You create a simple queue to control all traffic:
/queue simple
add max-limit=200M/200M name=sfq-default queue=sfq-default/sfq-default target=192.168.88.0/24
The max limit of the queue must be less than the max speed with fasttrack.
  1. You disable the default fasttrack rule from the firewall - don’t delete it, it’s useful for testing.
This should solve any bufferbloat issues quickly since it sets a hard limit for all your WAN bandwidth and it dynamically divides it equally among each client connected to the router as required (fair queuing).
Speed test again…
Using Fasttrack for gaming traffic
COD is used here, but any other port specific traffic can be marked.
  1. The connections need to be marked:
/ip firewall mangle
add action=mark-connection chain=forward comment=fasttrack-udp-dw-con dst-port=“” new-connection-mark=fasttrack-udp-dw-con passthrough=no port=3074-3078,27000-27059 protocol=udp
  1. A rule is created in the firewall for each connection:
add action=fasttrack-connection chain=forward comment=“Fasttrack udp dw games” connection-mark=fasttrack-udp-dw-con
These rules will let COD traffic bypass the QOS queue and prioritize this traffic over everything else, thus minimizing latency.
Make sure you move those rules up to were the default Fasttrack rules are with Winbox.
can i add which wan to use with this? i would like to use wan2 instead of wan1,
You can change the in. interface in /ip firewall mangle or /ip firewall filter (clearly accessible in Winbox). You can also fasttrack the ports directly without marking the connections first - 1 step instead of 2, so it should save a little CPU - a dev would need to confirm if this is the case or not.
