New Hap AC2, no internet
Hi, my previous routers all I had to do was change MAC address and they would work.
I just got the Hap AC2, changed ip, changed the MAC address, and no internet, dhcp client can’t get an address. What am I doing wrong?
[admin@MikroTik] > export compact hide-sensitive
# jan/02/1970 00:25:56 by RouterOS 6.45.7
# software id = 8LK7-GMFU
# model = RBD52G-5HacD2HnD
# serial number =
add admin-mac=CC:2D:E0:FB:1C:64 auto-mac=no comment=defconf name=bridge
set [ find default-name=ether1 ] mac-address=
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-XX disabled=no distance=indoors frequency=auto mode=ap-bridge ssid=MikroTik-FB1C68 wireless-protocol=802.11
set [ find default-name=wlan2 ] band=5ghz-a/n/ac channel-width=20/40/80mhz-XXXX disabled=no distance=indoors frequency=auto mode=ap-bridge ssid=MikroTik-FB1C69 wireless-protocol=802.11
add comment=defconf name=WAN
add comment=defconf name=LAN
set [ find default=yes ] authentication-types=wpa2-psk mode=dynamic-keys supplicant-identity=MikroTik
/ip hotspot profile
add name=dhcp ranges=192.168.1.10-192.168.1.254
add address-pool=dhcp disabled=no interface=bridge name=defconf
add bridge=bridge comment=defconf interface=wlan2
add address=192.168.1.1/24 comment=defconf interface=ether2 network=192.168.1.0
/ip dhcp-client
add comment=defconf dhcp-options=hostname,clientid disabled=no interface=ether1
add address=192.168.1.0/24 comment=defconf gateway=192.168.1.1 netmask=24
set allow-remote-requests=yes
/ip dns static
add address=192.168.1.1 name=router.lan
add action=drop chain=forward comment="defconf:  drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
add action=masquerade chain=srcnat comment="defconf: masquerade" ipsec-policy=out,none out-interface=ether1 out-interface-list=WAN
/tool mac-server
/tool mac-server mac-winbox
Looks like this is related to Mikrotik’s dhcp-client ignoring vlan 0, have to setup a bridge to change the vlan to get it to work, but I think this is using extra CPU?
Solution at http://forum.mikrotik.com/t/rb2011-how-do-i-strip-tagged-vlan-0/94770/1
It shouldn’t increase CPU usage by much (probably it wouldn’t be noticeable) … as this is your WAN, every bit will have to pass CPU anyway for firewalling etc. HW offload already doesn’t apply.
Just downgrade on long term 6.44.6
You have your local ip 192.168.1.1 on ether2 yet you are doing DHCP on Bridge
