New Hap AC2 setup. Couple of questions/problems
I’m in the process of replacing my old router with a Microtik Hap Ac2. I have it up and running but am running into a few problems. I’m not able to browse my internal lan machines from my wireless devices. The other issue i’m seeing is my internal lan is very slow. I stream recordings from my pvr PC to other wired clients via Kodi and the recorded videos are stuttering and timing out when watching on another client on the lan. Here’s my export from the router. Just wondering if there are any suggestions for me. Browsing to the internet seems ok although I did get a few buffers when streaming from discovery.com
This router is replacing a netgear nighthawk router that had the wifi fail. I’ve never had any problems streaming content on my internal lan previously. I also tested copying a large(3GB) file and the transfer speeds are about 1/3 rd of the speed from my old router. Any suggestions would be appreciated.
add admin-mac=74:4D:28:0C:AD:A3 auto-mac=no comment=defconf name=bridge
add comment=defconf name=WAN
add comment=defconf name=LAN
add authentication-types=wpa2-psk eap-methods="" management-protection=allowed \
    mode=dynamic-keys name=profile1 supplicant-identity=""
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-XX \
    disabled=no distance=indoors frequency=auto mode=ap-bridge \
    security-profile=profile1 ssid=Comet wireless-protocol=802.11
set [ find default-name=wlan2 ] band=5ghz-a/n/ac channel-width=20/40/80mhz-XXXX \
    security-profile=profile1 ssid=Comet5g wireless-protocol=802.11
add address-pool=default-dhcp disabled=no interface=bridge name=defconf
add bridge=bridge comment=defconf interface=wlan2
    192.168.88.0
/ip dhcp-client
add comment=defconf dhcp-options=hostname,clientid disabled=no interface=ether1
add dns-server=192.168.88.1
set allow-remote-requests=yes
/ip dns static
add address=192.168.88.1 name=router.lan
    established,related,untracked
    invalid
    in-interface-list=!LAN
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
add action=drop chain=forward comment="defconf: drop invalid" connection-state=\
    invalid
    "defconf:  drop all from WAN not DSTNATed" connection-nat-state=!dstnat \
add action=masquerade chain=srcnat comment="defconf: masquerade" ipsec-policy=\
    out,none out-interface-list=WAN
/system clock
set time-zone-name=America/Chicago
/tool mac-server
/tool mac-server mac-winbox
Thanks,
Jason
Your configuration looks ok. I would check cabling issues in the ethernet lan side. You can check the status in the Mikrotik with something like this (it is from a hAP ac, slightly different as it has the sfp1 port:
[admin@MikroTik] > /interface ethernet monitor [find]
                        name: ether1     ether2     ether3     ether4  ether5  sfp1
                      status: link-ok    link-ok    link-ok    no-link no-link no-link
            auto-negotiation: done       done       done       failed  failed  done
                        rate: 1Gbps      1Gbps      1Gbps
                 full-duplex: yes        yes        yes
             tx-flow-control: no         no         no
             rx-flow-control: no         no         no
                 advertising: 10M-half   10M-half   10M-half
                              10M-full   10M-full   10M-full
                              100M-half  100M-half  100M-half
                              100M-full  100M-full  100M-full
                              1000M-half 1000M-half 1000M-half
                              1000M-full 1000M-full 1000M-full
    link-partner-advertising: 10M-half   10M-half   10M-half
                              1000M-full 1000M-full 1000M-half
                                                    1000M-full
          sfp-module-present:                                                  no
Also, check the topology of your cabled/wireless network, in case one of your devices is making bridge loops. The log can help there. See /log print output.
You can test cable with
admin@MikroTik] > /interface ethernet cable-test numbers=[find]
    cable-pairs:                         open:2  open:0
                                         open:2  open:0
                                         open:2  open:0
                                         open:2  open:1
The number after “open” is an estimation of length of cable in case something is plugged in but unplugged at the other side.
Yup, I see nothing that stands out in terms of creating your situation.
This one is now redundant, left over from default config, you can remove.
/ip dns static
Here most people put in a few choices
set allow-remote-requests=yes servers=
8.8.8.8,8.8.4.4,208.67.220.220,208.67.222.222
I would try if not already done is putting in an antenna gain manually of +2.
Not sure if the latest firmware does that automatically??
Thanks for the help. It ended up being one of my cheap 5 port trendnet switches that was bad. Hooked up the PC in that room direct to ethernet and things worked great. I can connect to my lan devices from wifi again and copy speeds on the lan are back to normal. I’m getting about 20mb/s copying large files via wifi. Not sure if that’s normal or if I need to do some further tweaking.
