I got HAP ac2 for home network. The router transmits wifi with working internet to phones, tv, but if I try wired connection to PC I get no internet and “ehthernet doesn’t have a valid IP configuration” error if I try troubleshoot network problems. All setting are default other than setting wifi name, pasword and region. Any idea how can I fix it? Thanks
anav
November 12, 2020, 5:02pm
2
By posting your config to see where it all went wrong…
nov/13/2020 14:36:27 by RouterOS 6.47.7
software id = 8RR4-JW42
model = RBD52G-5HacD2HnD
serial number = D7160C29CA9A
add admin-mac=48:8F:5A:BB:E1:B8 auto-mac=no comment=defconf name=bridge
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-XX country=lithuania disabled=no distance=indoors frequency=auto installation=indoor mode=ap-bridge ssid=MikroTik wireless-protocol=
802.11
set [ find default-name=wlan2 ] band=5ghz-a/n/ac channel-width=20/40/80mhz-XXXX country=lithuania disabled=no distance=indoors frequency=auto installation=indoor mode=ap-bridge ssid=MikroTik
wireless-protocol=802.11
add comment=defconf name=WAN
add comment=defconf name=LAN
set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk mode=dynamic-keys supplicant-identity=MikroTik
/ip hotspot profile
add name=dhcp ranges=192.168.88.10-192.168.88.254
add address-pool=dhcp disabled=no interface=bridge name=defconf
add bridge=bridge comment=defconf interface=wlan2
/interface detect-internet
set detect-interface-list=all
/interface wireless access-list
add comment="Darbo laptopas " interface=wlan1 mac-address=56:1F:E2:A8:A3:A6
add comment="Telikas " interface=wlan1 mac-address=E8:F2:E2:8F:9C:AA
add address=192.168.88.1/24 comment=defconf interface=ether2 network=192.168.88.0
/ip dhcp-client
add comment=defconf disabled=no interface=ether1
set allow-remote-requests=yes
/ip dns static
add action=accept chain=input comment="defconf: accept to local loopback (for CAPsMAN)" dst-address=127.0.0.1
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
/ip upnp
set enabled=yes
/ip upnp interfaces
add interface=bridge type=internal
add interface=ether1 type=external
/system clock
set time-zone-name=Europe/Vilnius
/system identity
set name="Marius"
/tool mac-server
/tool mac-server mac-winbox
bpwl
November 13, 2020, 12:54pm
4
This is indeed a very standaard configuration. Pure default. And that works normally very well.
Where does the “ethernet doesn’t have a valid IP configuration” appear. Probably in the PC itself.
Check the ethernet setting of the PC . It should be on “Automatic (DHCP)” or “Automatic IP address” and “Automatic DNS” on the interface.
The PC should get an IP address like 192.168.88.253/24. The PC should be able to PING 192.168.88.1.
If you get an auto IP address 169.254.x.x , try another cable.
aesmith
November 13, 2020, 2:01pm
5
Shouldn’t the address be on the bridge not on ether2?
mkx
November 13, 2020, 2:03pm
6
Shush, this is @anav ’s part to say
bpwl
November 13, 2020, 3:25pm
7
That’s how you know it’s a default config
anav
November 13, 2020, 4:39pm
8
This is what I recommend, in answer to MKX …
add admin-mac=48:8F:5A:BB:E1:B8 auto-mac=no comment=defconf name=ether2 bwahahahahah
But seriously
yes…
how dare anyone answer before I… subtract 20 points from all your houses.
Aerosmith got it right.
The only other thing is I would not activate UPNP unless you can justify its need.
bpwl
November 13, 2020, 6:42pm
9
The only other thing is I would not activate …
??? And what with this ???
I hope we are not confusing the OP with all this quip.
anav
November 13, 2020, 8:55pm
10
I have no idea of the purpose of that part of the config.
I know when my IP changes on my bell fibre connection I have to manually assign the new gateway to the routing otherwise no dice, unlike my cable connection which automagically routes to the new gateway. Perhaps that feature is designed for those instances??
aesmith
November 14, 2020, 11:29am
11
I stand to be corrected of course, but I don’t think it would help in that case. As far as I’ve learned, Detect Internet needs to be able to reach something on the Internet and then dynamically changes the Interface List membership of the egress interface. If you’ve lost the gateway I can’t see how it could work at all. Drifting off the topic, how do you get your configuration from Bell, is it DHCP, PPPoE or what? That should upgrade the gateway and default route I would have thought.
aesmith
November 14, 2020, 11:32am
12
My new router assigned the address to the bridge as default. Maybe it’s version dependent, maybe depends on the shipping version of RoS.
