I think I’m getting crazy. I got a brand new hAP ax3 C53UiG+5HPaxD2HPaxD device.
I created a new bridge in default configuration and added the wifi2 port to this bridge. Then I created a dhcp-client for this bridge.
After I configured the wifi2 in mode station, the connection goes up and I think all fine.
But I didn’t get an IP adresse from the dhcp server.
Things I tried:
Used an other ssid (mikrotik ap with dhcp server) with the same result.
When I removed the wifi2 from the bridge and changed the dhcp-client directly to the interface I got an ipaddress.
I’ve wondered, when I add the wifi2 back to the bridge - the MTU size of the bridge didn’t automaticaly reduced to the MTU size of the wireless connection, but the wireless connection is already up.
Software Version 7.7 and 7.8 tested without change.
Any idea what happened?
Any necessary informationen needed?
I bought a hAP ax3 specifically for this purpose, to use it as a wireless station to share the WiFi through the Ethernet ports with devices without WiFi capabilities and encountered with the same issues “namex” found.
As “namex” said it works if I remove the wifi2 interface from the bridge and use it as a WAN interface but I don’t want to double NAT.
Ideally I just want the wifi2 interface in station mode LAN bridged with the Ethernet ports.
Ax to ax, yes you can.
Ax to legacy, nope. Not possible in an easy way.
It CAN be done if you put something like EOIP over both ax/ legacy endpoints but that’s not really standard setup.
