An awesome product would be a RB751U-2HnD with poe output on eth1 marked with yellow on the poe output port like the RB750UP.
An all in one solution for poe, router, and access point with the ability for watchdog to reboot not only the router but also the poe port to reboot the outside cpe.
This would be the holy grail of routers in my opinion. customers wont have to look for different items if they need to reboot something, and if the roof equipment locks up, the watchdog will reboot the poe along with the router.
plug in the router with a normal dc adapter and plug the cpe into eth1 and customer has 4 eth ports to use as well as the wireless. just have to make sure and keep the firmware current so that new devices that come to market will successfully connect to the access point.
Thoughts?
Josh
p.s. thank you Mikrotik for the 411GL!
any plans for 411G with metal ethernet port?
