New Hotspot voucher generator
I would like to introduce to you a set of 3 programs I have worked on related to HotSpot Manager.
The first one is a freeware Windows CLI. It’s attached to this email .
It is very easy to use.
The structure is as follows:
MicrotikCli.exe ip_adresse api_user api_pwd num_of_users username_length password_length character_type(num or char) Profile
Exp: MicrotikCli.exe 192.168.0.254 api1 1234 30 5 4 num Free4w
The program generates a csv file [ Vouchers_20151120.csv].
I am working actually on the windows version and the android version.
Please take time to test the program and do not hesitate to come back to me should you have any other ideas/suggestions.
Kudos for sharing it! :smiley:
Suggestion: Add another parameter: “Pwd same as login” (as in UM Users > Add > Batch).
That way it can be used also to generate “access code” or “pin” style hotspot credentials.
It’s done :wink:
New ver. : put voucher for generate pwd same login.
i am tested but view error rhan close
You have to create in advance the Userman Profile.
not exist please updtae the lind
Hello, I found this incredible app for android is called MikroTicket https://fhx47.app.goo.gl/mikroticket generates tickets or vouchers for access by hotspot mikrotik and you can configure access times, bandwidth, time runs and makes automatic removal of the vouchers, I use it in my business. https://youtu.be/DZqg4BIMEUw Regards
File not found :slight_smile:
