we have found a problem with all intels new network chipsets.
i’m talking about the intel 10/100 82551ER chipset
and also the intel 10/100/1000 82541PI chipset.
both are reconized as a intel 10/100pro and a 10/100/1000pro
and work like a charm if you use normal ethernet connections.
BUT
if you use vlans no go…
tried with v 2.8 and 2.9 put in a good old intel 10/100pro card changed the vlan from interface and bang it works again.
also changed MTU’s to be sure it’s not the more than 1500 issue.
but still no go…
for normal ethernet connections no problem but if you try vlans…
nope
any comment???
ps it’s not a bad card.. it tried with 16 different ones…
under linux they are loaded with the same e100 driver and e1000driver like the rest…
what’s different with your drivers???
how mutch do you guys need to make it supported???
you may send the invoice…
i think he means that the cards already work in 2.9rc1 and that you can safely upgrade, as he will help you with it if you should have any problem (2.9 is out of beta)
I picked up 3 of the new Supermicro Xeon boards.
They run RouterOS like a “bat out of He11”..
Only one issue.. The onboard NICs shut down after about 1/2 hr.
No reason no error… If the interface is disabled then enabled,
the interface will again forward packets.
I had to install a Compaq 64bit 10/100 card (Like a rock)..
Anyluck on the the problems with this chip set? As we have several box’s we are try all with this onboard… And need to know how long we have to wait or look for another box..
