new IP block not working
i just get a new /25 assigned to me by my provider (174.XXX.50.128/25)
i was told to use my existing default route (64.XXX.133.XXX)
Router A: i added 174.XXX.50.129/25 to ether3, plugged my laptop into ether3 addressed my laptop to 174.XXX.50.150/25 and could surf fine.
Router B:now I plugged a mikrotik router into ether3 gave it an address of 174.XXX.50.150/25, added a default route of 174.XXX.50.129 and i could not ping out to the internet. i couldnt even ping 174.XXX.50.129 and from router A i could not even ping router B.
What is going on?
Thank you
If you set up everything correctly then my best guess is the ARP table on the default gw..
/Henrik
You need to use a gateway in the same subnet as your range. Possibly they setup a new range and are just routing it thru the old one ?
Sam
Changeip, I thought the same thing but the ISP said to use the same /30 that my original 64.XXX.XXX.XXX/28 used. As i stated i addressed my notebook that sam as router B and all was well. Ill will be bat at that site in a few days and see what i can find.
Thank you for the reply
/Henrik[/quote]
I will take a look at the ARP table
Thank you
