So are the new ipv6 pools supposed to be an implementation of DHCPv6 and if so how do you set the M and O flags in router advertisements?
See:
http://tools.ietf.org/id/draft-ietf-ipv6-ra-mo-flags-00.txt
See:
tried to use pools for ipv6 over PPPoE, but aren’t working.
if I set the prefix directly on user secret, it works okay.
if I set a pool on profile, the prefix aren’t routed to ppp interface. =/
pppoe support will be added in v5.9
