Dear Sirs,
just bought a mAP lite, connected to his power supply and to ethernet port (the Link led on switch is ON and the Act Led is OFF )
From winbox no neighbour is detected and no direct access to 192.168.88.1.
I’ve set my pc to 192.168.88.100 and no ping back from 192.168.88.1.
I’ve used mAP, and RB951 without issue until now, is this device faulted, how can I debug it?
On most of APs you should make first configurations from wifi
Ok, I get it now, thanks!
this is my scenario:
A >>> B >>>> C
A: external ruoter with dhcp and AP
B: the mAp should connect to A by wifi
C: a pc without wireless that should connect to A
To connect C to A I can use: CPE - Short for “Customer Premises Equipment”?
yes, CPE is mode when RB is used as wifi client
don’t forget to bridge ethr and wifi on mAP lite and turn off dhcp on it
It works fine, thank you!
