Just setup and configured “The Dude”…nice MikroTik!
I would like to use multiple maps for monitoring different nodes. I am running v1.2. I can add a new map successfully, but when trying to open the map, the map remains in the “Loading Map” phase and never loads the newly created map. Any ideas would be greatly appreciated.
Thank you for the reply normis. I have actually seen this in multiple dude version installs, and on two different servers. I am a little hesitant to go to v3 until the final release is published. In my opinion, the Dude is a very powerful and useful program, I am just a little confused on why I have not been able to get this to work.
I have created multiple maps, and tried opening them from both our clients and server. When I double-click the map to open it, the map shows as “Loading”. I also get the same result when opening the new map separately.
I had the lost map problem with 2.2 i havent had that perticular problem in 3 although other little issues have come up with 3. Ya win some and lose some. Your best off to take notes on what youve got and just redo things if they get lost or damaged.
When I first got 2.2 installed I had the same issue. I created a new map and loaded that one.
From what I understand it is trying to load a non-existent initial map.
I upgraded from 2.2 to 3.0b8. The only issue I saw in the upgrade was a background image was enabled (wasn’t in 2.2) and when I changed the color the ap.avg image conquered my screen! I disabled the image and returned to normal.
