New map
Hello All,
I’ve a big issue on creating new network maps. In fact i can’t create a new map, i thought it was because there was a limit of how many maps i coul create. But even if i delete a map i can’t crete a new one. I can add a map in the network map list, but impossible to load it.
Some one has an idea of why?
Create the new map and do not use apply button, use ok!!Do not have the “loading” problem.(xml)
Ok i’ll try this and keep you informed, thx
Thanks, it works perfectly :smiley:
