There is another aspect: potential buyers tend to hold off purchasing decisions in anticipation to get a better performing equipment with a longer lifespan. This obviously affects sales so it’s not a good idea to “stretch “ the time frame between product announcement and availability. Goes without saying that a product needs to be ready.
I would be hoping to see a CRS418-8P-8G-2S+5axQ2axQ-PC with one single external supply brick and a much smaller enclosure (about the size of the PCB). Similar to other -PC models.
It has the ideal number and type of ports for my home usage, including several ports with PoE out both passive and 802.3af/at, and it would be fast enough for my internet access and LAN requirements.
(of course it would be nice to have 2.5G ports but I do not really need them)
And are we sure these S009* will come out ?
@normis any hint please ? ![]()
We really miss a 8 ports (non PoE / PoE) switch running RouterOS, with switch rules and so ones.
CSS610 are low budget switches, but some kind of a "patch" in our customers' RouterOS infrastructures, a thorn in the side, lacking tooling / scripting possibilities, switch rules etc...
We sometimes use RB5009 configured as switches only, but then not really relevant in terms of pricing...
And CRS326/328 are sometimes too big for edge deployments...
Many thanks ![]()
avis99
You have expressed exactly the point I was trying to make in my previous posts, but in a much better way!
I keep holding my next Mikrotik purchases for the last 6 months, for this very reason!
I wonder when Mikrotik will come up with the idea to launch a simple - and above all, cheap (about half the price of the RB5009) - Ethernet router (with more than 5 ports) that can handle a 1 Gbps connection without relying on FastTrack.
Right now, if someone needs a device like that, they pretty much have to go for the RB5009.
The boys and girls at MikroTik want to eat dinner as well... when you can't afford a MikroTik router, just buy a whitebox. It won't have the RouterOS features but it will be fast.
Like any company, MikroTik wants to make a profit, but I don't think they're greedy.
It’s just that their product lineup often lacks balance - a balance that would still allow them to turn a profit.
I dont agree woth you for what u get at their price point its hard to get anywhere else. Sure they have issues more than I would like to admit BUT they already offer more than competitors offer.
It's true that their feature-to-price ratio is excellent, but that doesn't mean the hardware lineup is flawless.
If a user simply needs reliable 1 Gbps routing without relying on FastTrack (e.g., for complex queueing or mangle rules), the leap in price to the RB5009 is steep.
Asking for a mid-tier hardware refresh between the hEX and the RB5009 isn't ignoring their value, it's just asking for better product scaling.
And the competition price for a similar device is ... ? To fill the gap you could also look at AX2/AX3 (and not use wifi part).
Thank you for your feedback.
You are right that the AX2 or AX3 could be an answer here. However, it's a pity to waste resources on Wi-Fi hardware that will just be disabled anyway. Furthermore, it would be really useful to have more ports.
In general, here is a lack of a purely wired solution – a multi-port Gigabit router priced similarly to the AX2 (or less), with enough CPU power to handle a 1 Gbps connection with complex queues and mangle rules without FastTrack.
Okay, I won't complain anymore. ![]()
As I see it
Eggs are sold by the dozen.
Mikrotik makes 8-egg (hex/l009) and 24-egg (RB5009) boxes, as well as some 11-egg (ax2) and 13-egg (ax3) boxes.
Yeah but i want a 10 egg carton!!!!!!!!!
Better go buy ubiquity now and spend 6x as much as you would for a mikrotik setup and barely come close to mikrotik ![]()
Exactly! I just want a standard 12-egg carton without the built-in egg warmer (Wi-Fi)! ![]()
But fair enough, message received. I'll just have to save up for the 24-egg box! ![]()
If I go buy the 6x more expensive setup, I won't have any money left to buy the actual eggs! ![]()
Anyway, thanks for the chat guys. I'll stop searching for the mythical Mikrotik 10-egg carton for now.
Jokes about egg cartons aside, you can bend reality all you want, but there is undeniably a massive gap in the current lineup. There is a real, tangible niche right between the hEX and the RB5009 for a purely wired router that can actually handle a 1 Gbps connection with complex rules.
A lot of users genuinely need a capable 1 Gbps wired router that doesn't force them to jump straight to the RB5009 price point.
Yep, that would be what was expected of the l009, but that It cannot deliver, the more logical performance/price order:
- hex
- l009
- Rb5009
Came out as:
- hex, l009
- Rb5009
Spot on. The L009 had the potential to be that exact middle ground, but as you pointed out, the CPU performance just isn't there for heavy 1 Gbps routing without FastTrack.
It has the right form factor and ports, but lacks the raw power. So that empty #2 spot in your list is exactly what I'm talking about – we just need MikroTik to fill it with something like a beefed-up L009 or a stripped-down RB5009 => RB5009 Lite.
I agree that the RB5009 cost nearly 2 times as much as the L009.
But given your situation, I would cry once and spend the extra for the RB5009. Then you won't need to cry again for a longer period of time. Since you are using PPPoE that will also use extra processing power, so having the extra CPU in the RB5009 will help, especially if you plan on using other things that will prevent the use of FastTrack.
However, how much are you spending per month on your 1Gb internet per month? How many months of internet would cover the cost of the difference in price?
What our company would appreciate, would be either DIN rail holder for hEX S or even better something like hEX IoT - case with the capability to attach the DIN rail (similar to KNOT LTE 4) plus LED's visible from the RJ45 port side (extension with light conductors seems to be sufficient). The possibility of powering via phoenix like connector (such as RB5009) plus power supply sold separately (as for integration with our products is not really needed and we are just throwing them away) would push it to the edge of perfection...
That's a pragmatic way to look at the price difference. But in my case, I don't use PPPoE. Since I don't have that extra overhead to worry about, the RB5009 is way more raw power than I actually need.
It just highlights the gap in the lineup even more.
Your "buy once, cry once" logic sounds exactly like a car salesman trying to upsell me: "ust pay a bit extra for the premium model, you'll definitely need that extra horsepower someday!"
Welcome to 2026: Where a budget-friendly, non-FastTrack 1 Gbps Ethernet router shouldn't be a myth.
MikroTik 2027 resolution: Stop making us choose between underpowered and overpowered. Give us the mid-tier Gigabit king.
I don't think the RB5009 is overpowered for 1Gbps internet. It's exactly the right specs if you need 1Gbps VPN throughput (with WireGuard).
