Hy,
i just saw on a famous EU dealer a new mPCI from Mikrotik: R52H (it’s available from this morning).
It reports:
Description> MikroTik introduces the R52H wireless 802.11a+b+g miniPCI card for multiband high speed applications, with up to 350mW output power. It works on 2.192-2.539 and 4.920-6.100GHz frequency range and supports Turbo mode for faster transfers. The card performs best when coupled with the MikroTik RouterOS.
R52H is optimized to work with MikroTik Nstreme protocol to reach extra long distances at a great speed. The Nstreme protocol is MikroTik proprietary wireless protocol created to overcome speed and distance limitations of IEEE 802.11 standards and to extend point-topoint and point-to-multi point wireless link performance. The new Nstreme-dual protocol designed to provide real full-duplex communications over wireless with a pair of wireless cards – one for transmitting data and one for receiving.
Features :
➔ Turbo, 802.11a, 802.11b and 802.11g IN ONE
➔ Operates in both 2.4 GHz and 5 GHz wireless bands
➔ Support MikroTik Nstreme
➔ Extended distances and higher speeds due to better output signal power
➔ FCC and CE approvalSpecifications : >
Frequencies 802.11b/g 2.312 – 2.497 (5 MHz step)
802.11a 4.920 – 6.100 (5 MHz step)
Chipset
Atheros AR5414
Security
Hardware 64 and 128 bit WEP; Hardware TKIP and AES-CCM
encryption; 802.1x WPA authentication
Modulation
802.11b+g: DSSS, OFDM for data rate >30Mbps
802.11a: OFDM
Host Interface
Mini-PCI form factor; Mini-PCI Version 1.0 type 3B
suggested only for motherboards that are
produced after 2004
Power Requirements
3.3V +/- 10% DC; 400mA max (300mA typ.)
Tx Power / RX Sensivity
IEEE 802.11a: 24dBm/-90dBm @ 6Mbps
19dBm/-70dBm @ 54Mbps
IEEE 802.11b: 25dBm/-92dBm @ 1Mbps
25dBm/-87dBm @ 11Mbps
IEEE 802.11g: 25dBm/-90dBm @ 6Mbps
20dBm/-70dBm @ 54MbpsTransfer Data Rate
802.11b:11,5.5,2,1 Mbps, auto-fallback
802.11g(Normal mode):54,48,36,24,18,12,9,6 Mbps, auto-fallback
802.11g(Turbo mode):108,96,72,48,36,24,18,12 Mbps, auto-fallback
802.11a(Normal mode):54,48,36,24,18,12,9,6 Mbps, auto-fallback
802.11a(Turbo mode):108,96,72,48,36,24,18,12 Mbps, auto-fallback
As you can see, the tech specs differ between the first and second part (e.g. frequency band), and the pdf on their sites point to the “old” R52.
I can’t find any news on this forum, neither on mikrotik or routerboard sites, regardings this new mPCI.
Can you provide it please?
73 de IZ3HAD
