new point with 4 x sxt 5 14 dbi
Hi all.
I have seup a new point with 4 x sxt 5 14 dbi and set up with ap and acl no problems.
Next i have 15 sxt 5 to give out to unit in the feld.
My q is: Is there a way where the unit just can point there ant to my multipoint and it Will connect on auto?
I kan only get it to work with 1 ap so if they are conect to the ant point to S and moving to N it Will not work ? Is there a way to set my multypoint up so the unit can point there ant to my multipoint from any 360 ? My plan is to use sms from dude wend there is link from unit to multipoint.
Cheers jimmy
Use the same SSID on all the sectors and set the sector name as Radio name to be able to identify which one you are connecting to.
Hi pukkita
Thx for reply.
New Q.
If i set 4 sxt 14 db on same ssid what about frq? Cuss if i use same frq on all 4 Will that be good ?
Send from mobile phone.
SSID and frequency aren’t dependent.
You should use a different frequency on each, do a spectral scan first on each sector to determine the best frequency for each sector.
Frequency you set on the AP (sector) will be followed automatically by the stations as long as you’re not using a “superchannel” frequency; if you set the same country on AP and stations there will be no problem for the stations “following APs”.
