just install atheros AR5413
im using my laptop near the MT router 5 meters only
the ping is =1 then =15ms =50ms not stable pinging after that i start downloading from internet throw this wireless @ 2mbit the ping still the same doesnt goes higher or lower,
any idea guys?
Make sure the antenna is connected to the connector nearer the middle of the board. The AR5413/14 cards are opposite the CM9.
John
i dont understand what do you mean
i have 2 connector in the board i connect it to one wrote on it main
its the the middel
what kind of notebook, radio and OS is meant?
the wireless forums are full with Windows having problems with wireless connections, especially using Intel Centrino chipsets and WPA/WPA2.
