Since this topic is starting to get replies, my thoughts on the topic
Wireless for Home and Office:
Dual Radio 802.11ac AP with āEnterpriseā AP appearance
MU-MIMO wave2 AC would be very much appreciated
More then Triple chain would also be beneficial (min 2x2 for 2.4Ghz, 3x3 preferred) (min 3x3 for 5Ghz AC, 4x4 preferred if wave2 device)
1x Gigabit with Passive POE and 802.3af/at in
To make it extra nice, an Extra Gigabit port with POE out to daisy chain another AP
$150 price point
I see a real need for these. Currently we deploy Ubiquiti Unifi for these cases, but they certainly arenāt perfect and the noise issue is a real problem. The hAP AC is a good step towards this, just less port and a different form factor so that attaching it to a wall or ceiling doesnāt look totally odd.
An AP does not need 10 Gigabit ports⦠1x Gigabit is enough
- Minimum 8 port CRS with POE out on all ports (12 ports would be nice)
Selectable 12v/24v/48v Passive POE out and 802.3af/at POE per port (250w / 300w total?)
9nth (13nth) SFP+ 10Gbit ports for DAC cables or SFP+ module
2x SFP+ Would be awesome if it doesnāt come at a too big of a price premium
CPU does not need to be very powerful
Enough power to do VLAN (un)tagging and bridging at least at 2 Gigabit or more
Internal power supply would be preferred. Dual for a premium model?
Rackmount and desktop mount
Basically a CRS226 with POE out on at least 8 ports
$375 price point
I see a need for these kind of āedgeā switch in wireless deploys (both tower and home/office). I donāt like using passive POE for everything and would like a solution to which I could could hook up my Access-Points and if needed some cameraās or phones. If you connect 5x or 6x AC access-points you want something bigger then 1Gbit as the uplink
We donāt have so many wireless devices that are L3, and those are clearly marketed as CPE only. We donāt have any AP devices that canāt function as routers
It might technically be a router, but if it has only 1 network port, for me itās just an AP (even if the port could also be used to hook up a client).
I guess people who only use WiFi clients have no problem in thinking of them as routers.
I would like to see some CRS Modells with 8,12 or even 16 10G SFP+ ports in 19" case for rack mounting.
They do not need heavy routing features, they would be useful as a top of rack switch.
