Yes. Thank you my friend. And the FULL reloaded is the 4011, but I was “waiting” some little cheaper (between 2011 and 4011) jajaja
But if this is the answer.. PERFECT…
Waiting in Europe for try it.
Do you really need router with 10 ports and wifi? Wouldn’t it be easier to have stuff nicely separated? i.e. have router for routing, switch for switching, AP for wifi?
For example
router will be probably hidden somewhere. It will never be positioned properly to utilize wifi coverage as much as possible. AP can be placed anywhere (ideally on ceiling, it is really big difference!)
router usually have limited switching abilities so you will likely hit some unexpected issue.
To be specific:
RB2011 has 5 ports limited to 100Mbit ethernet, other 5 ports and SFP cage share single 1Gbit line to CPU. That means any non-switched forwarding between two 1Gbit ports will be always limited to 1Gbit half-duplex speed! (Yes, I know it was not issue many years ago but now it is simply outdated)
RB4011 has each group of 5 ports shared 2.5Gbit line. Not bad, but if you expect to utilize all ports, you will hit the limit. And you can’t do wire-speed switching between separate groups of ports. In addition, RB4011 currently can’t use switch chip for VLAN filtering.
It would be lovely to have some “universal” device but as far as I can see, every model from RBx011 range has some issues
I have limited space and my RB2011 ports are full. I would like to see a desktop wireless product in the RB4011 price range with 4x 10G + 10x 1G (CRS-like with RB3011 power).
It depends my friend, but yes… for and “power house” like mine… I have 10 used, now I am using a RB493 extra like AP and Switch but my 10 ports are FULL right know, and the CPU average is getting high with everyday more VPN (L2tp + IPsec) users and the internet speed is getting higher everyday…
I would like to see a router with CCR1072 performance at RB2011 price (and of course at RB2011 mains power usage).
But hey, not everything we would like to see is possible today. Maybe in 5 years?
