New RB411U - Initial boot login admin <blank> failing, Help
I have assembled:
RB411U, R52, 2.4GHz Ant (Main), RB411U Case, 24v 1.25a 30W PS.
Using Winbox I can see the MAC and the IP 192.168.88.1
I click on the MAC and the packages download.
I then receive a Wrong Username Password.
(I have tried to put Hyperterminal [copied from Win XP Pro] using MS.com Link as a guide… I only get Gibberish on the terminal window).
(I also downloaded putty.exe from a thread here and have nothing showing up.)
What should I try now?
If you are getting gibberish, that is normally an incorrect serial port setting.
115200 8-N-1 are the correct settings in Hyperterminal or PuTTY.
