New RB433 boots but no internet connectivity on any port.
Today i bought a new rb433. I setup everything and finally when i connected the poe i could not login to router. The first thing that came to mind was that the connector might be faulty, so i replaced it. No luck.
The second thing i tried was to remove routerboard from case and put it on direct power. The device booted up but still no lan connectivity. On both poe and direct power the routerboard booted but i cannot login. The coimputer show me that there is no internet connectivity.
Is the routerboard maybe faulty? I have check and i can see that all the ethernets on routerboard is on and dimmed. I think the lan part is faulty.
Should i send the routerboard back to the seller?
Connect to the router with Null Modem cable and check the status of the Ethernet port, when cable is attached.
Try to run Netinstall and reinstall the router with it. If it is not possible, then return board to the seller.
Ok they have replaced the rb433 with a new one. :smiley:
