Hi everyone, new to the MikroTik world, had build a opnsense box in the past but wanted a smaller package and some nice features so got a rb5009ug+s+in running RouterOS v7.05. Very new to firewall and rules
I switched the WAN port from eth1 to eth8 succesfully (I need that eth1 for my 2.5gbps desktop) but now I’m trying to share a NAS/webserver which is running a reverse proxy via port 80/443 (I moved the web interface from TrueNAS to 81/444 and use Traefik on 80/443) using eth8. I can’t use the WAN IP since I have Cable Inernet in Canada and if you reboot/lose power for too long your IP changes so I want to bind it to whatever IP the DHCP client gets from eth8. This seems to be fine since I get an IP from the Cable modem in IP → Addresses
I googled a bunch of videos/guides, clearest one was from this one https://www.youtube.com/watch?v=jgKgsg9VlhY from Category5 Tech TV, but it’s still not working. Externally my WAN IP is not being picked up by my webserver and internally my WAN IP just puts me back to my mikrotik setup screen.
[admin@MikroTik] /ip/firewall/nat> print detail
Flags: X - disabled, I - invalid; D - dynamic
0 ;;; defconf: masquerade
chain=srcnat action=masquerade out-interface-list=WAN ipsec-policy=out,none
1 ;;; Web Server Port 80-81
chain=dstnat action=dst-nat to-addresses=192.168.88.247 to-ports=80-81 protocol=tcp in-interface=ether8 dst-port=80-81 log=no log-prefix=""
2 ;;; Web Server HTTPS 443
chain=dstnat action=dst-nat to-addresses=192.168.88.247 to-ports=443-444 protocol=tcp in-interface=ether8 dst-port=443-444 log=no log-prefix=""
And as per the video I added filters for local traffic
[admin@MikroTik] /ip/firewall/filter> print detail
0 D ;;; special dummy rule to show fasttrack counters
chain=forward action=passthrough
1 ;;; defconf: accept established,related,untracked
chain=input action=accept connection-state=established,related,untracked
2 ;;; defconf: drop invalid
chain=input action=drop connection-state=invalid
3 ;;; defconf: accept ICMP
chain=input action=accept protocol=icmp
4 ;;; defconf: accept to local loopback (for CAPsMAN)
chain=input action=accept dst-address=127.0.0.1
5 ;;; defconf: drop all not coming from LAN
chain=input action=drop in-interface-list=!LAN
6 ;;; Firewall port 80
chain=forward action=accept protocol=tcp dst-address=192.168.88.247 in-interface=ether8 dst-port=80-81 log=no log-prefix=""
7 ;;; Firewall 443-444
chain=forward action=accept protocol=tcp dst-address=192.168.88.247 in-interface=ether8 dst-port=443-444 log=no log-prefix=""
8 ;;; defconf: accept in ipsec policy
chain=forward action=accept ipsec-policy=in,ipsec
9 ;;; defconf: accept out ipsec policy
chain=forward action=accept ipsec-policy=out,ipsec
10 ;;; defconf: fasttrack
chain=forward action=fasttrack-connection hw-offload=yes connection-state=established,related
11 ;;; defconf: accept established,related, untracked
chain=forward action=accept connection-state=established,related,untracked
12 ;;; defconf: drop invalid
chain=forward action=drop connection-state=invalid
13 ;;; defconf: drop all from WAN not DSTNATed
chain=forward action=drop connection-state=new connection-nat-state=!dstnat in-interface-list=WAN
I hope this is clear, I just feel like something is missing
I woke up this AM and found your tread, super informative, has to be something to in there. It’s a snowstorm in Quebec so I’m about to take the kids out but here’s my config. Thanks for the reply! I used portchecker.co which said ports were open but any LAN traffic wasn’t able to access anything.
Let me know if I shoud post the config inline. DaSnipeConfig.rsc (7.47 KB)
In Mikrotik RoS,
One only has one port forwarding firewall rule in the forward chain, which is a generic rule that says, we will allow packets through the router (wan to lan) that have a destination port on the router that has an equivalent matching destination NAT rule configured… I dont particularly like the way they made this rule because they use the !syntax…
Basically it states drop any traffic from the internet heading towards the LAN except if they are valid dst-nat packets (as I stated above). add action=drop chain=forward comment=
“defconf: drop all from WAN not DSTNATed” connection-nat-state=!dstnat
Therefore your rules here are misplaced for starters being in the forward chain, and not in the right format anyway, they need to be removed!
add action=accept chain=forward comment=“Firewall port 80” dst-address=
192.168.88.247 dst-port=80-81 in-interface=ether8 protocol=tcp
add action=accept chain=forward comment=“Firewall 443-444” dst-address=
192.168.88.247 dst-port=443-444 in-interface=ether8 protocol=tcp
Now lets take a look at sourcenat rules.
add action=masquerade chain=srcnat dst-address=192.168.88.0/24 src-address=\ {good if you intend to use public IP to access server from within the LAN - aka hairpin nat)
192.168.88.0/24
add action=masquerade chain=srcnat comment=“defconf: masquerade” \ {good, standard needed rule}
add action=src-nat chain=srcnat dst-address=192.168.88.0/24 src-address=
192.168.88.0/24 to-addresses=74.58.142.138 {Garbage: Get rid of this rule, }
Now lets take a look at the dst nat port forwarding rules…
add action=dst-nat chain=dstnat comment=“Web Server Port 80-81” dst-port=
80-81 in-interface=ether8 protocol=tcp to-addresses=192.168.88.247
to-ports=80-81
add action=dst-nat chain=dstnat comment=“Web Server HTTPS 443” dst-port=
443-444 in-interface=ether8 protocol=tcp to-addresses=192.168.88.247
to-ports=443-444
Anytime users on the same lan as the server will access the server via the routers own public IP address (loopback) as noted above you need to use the hairpin source nat rule.
In addtion, however, if you have a dynamic wanip we cannot use in interface=WAN (ether8) etc, because that blocks users coming from the LAN.
As discussed in the linked article many ways to do this, easiest is to use your own IP cloud service. Also to port not required if same as dst-ports.
Thanks, that did the trick, now to figure out what’s going on with my domain name and reverse proxy setup, pointing to my IP works, and it’s redirecting traffic to the NAS, but something is up with my setup. Appreciate the quick response and help!
