New RC13 npk does not upgrade in the dude
I alway’s add my new packages in the dude for upgrading my core AP’s. In the dude with the new RC13 package, it shows and allows me to click, but it won’t upgrade, if I look in the devices/routeros the error is “no packages available”.
How can I fix this?
this is known problem and we are working on that.
as a workaround you can upload packages for every router (even using dude) and then restart router
any idea when this will be fixed? I’ve got about 100 devices that I’m going to need to upgrade soon, and the thought of a manual upgrade is not a pleasant one.
same here 250+
any else having unreliable upgrades for 2.9.50 also? I’ve had 3 that failed to upload… if I can’t do 2.9 with the dude either those 100 devices just jumped to over 500 :frowning:
Update: the problem with v3 is limited only to the mipsel processors, the powerpc packages upgrade without problem.
